Add a size guide to products which belong to a specific category
4 years 9 months ago #338027 by yanliom
I'm trying to add a size guide only to products which belong to a specific category.
It can be in the form of a link or an image.
I tried using a read only custom field but it didn't work out.
Any suggestions?
Thank you in advance,
Yannis
4 years 9 months ago #338028 by nicolas
You can create a custom field of the table "item" of the type "custom text" and enter the text directly in the custom field settings.
4 years 9 months ago #338040 by yanliom
Thank you,
yes, indeed I used the custom text to write some HTML!
Thank you,
Yannis
Time to create page: 0.248 seconds
