- Thank you received: 3
How can I display the products of a vendor in a regular Joomla Module?
- coolcatcreations
4 years 8 months ago #339430
by coolcatcreations
How can I display the products of a vendor in a regular Joomla Module? was created by coolcatcreations
Hi! I want to display all products by one vendor in a regular Joomla module.
I tried the Hika Market module but there is no vendor selection.
I tried to insert it by TAG but there is no vendor selection either.
thanks,
Elisa
thanks,
Elisa
4 years 8 months ago #339455
by Jerome
Replied by Jerome on topic How can I display the products of a vendor in a regular Joomla Module?
You can use the HikaShop category filter and select the vendor root category.
- coolcatcreations
4 years 8 months ago #339460
by coolcatcreations
Replied by coolcatcreations on topic How can I display the products of a vendor in a regular Joomla Module?
Hello Jerome,
I can't find any module where I can select anywhere a vendor or category to filter for. What is the Name of the module?
Thank you
Elisa
Thank you
Elisa
4 years 8 months ago #339479
by Jerome
I'm not talking about HikaMarket.
I'm saying that you can do a classical HikaShop product listing module and select a "category" (and it's sub categories).
In HikaMarket, when vendors creates products, they can be under the vendor root category.
CF : www.hikashop.com/support/documentation/1...nfig_market_category
It means that all vendors products can be found under their root category, which helps the display by using a filter on the category instead of the vendor ID.
The following user(s) said Thank You: coolcatcreations
- coolcatcreations
4 years 8 months ago #339481
by coolcatcreations
Hi Jerome!
Either my installation is broken or I am blind. What is the name of the Hika Shop Product Module? I can’t find it in Joomla 4 Site Modules.
Elisa
Elisa
4 years 8 months ago #339486
Replied by nicolas on topic How can I display the products of a vendor in a regular Joomla Module?
The name is "HikaShop content module".
It's the standard module which comes with HikaShop. When you create a new module instance in the Joomla modules manager, you can select it.
Several module instances of that module are pre installed with HikaShop like the "random products", the "best sellers", etc.
- coolcatcreations
4 years 8 months ago #339487
by coolcatcreations
Hi Jerome,
I found it. The Modules name is "HikaShop Content Module" - and for everyone who is maybe confused like me: the settings are in the 3rd Tab
- coolcatcreations
4 years 8 months ago #339488
by coolcatcreations
Thank you Nicolas, we apparently posted almost the same time. I was confused because I somehow did not see the third tab and tought the content module has just a class setting.
