Favorites products
4 years 6 months ago #340093 by komir
Favorites products was created by komir
-- HikaShop version -- : 4.5
-- Joomla version -- : 3.10
-- PHP version -- : 7.4
Hi is Hikashop have a Favorites product?
Something like users can select their favourites products.
Thank you
4 years 6 months ago #340103 by nicolas
Replied by nicolas on topic Favorites products
There are two ways to do it.
You could use the wishlist system:
www.hikashop.com/support/documentation/5...config.html#features
You could use the "like" plugin:
www.hikashop.com/marketplace/product/155-product-like-btn.html
4 years 6 months ago #340156 by komir
Replied by komir on topic Favorites products
I have enabled it. Now button is displayed in product details.
My question is how to display, that button, on the product in the category list view?
Thank you
4 years 6 months ago #340163 by nicolas
Edit the settings of your menu items via the joomla menu manager. There, under the "products options" tab, you'll have a display setting for the add to wishlist button.
4 years 6 months ago #340214 by komir
Thank you
One more is it possible to be some image of the heart, not text?
4 years 6 months ago - 4 years 6 months ago #340215 by Philip
Replied by Philip on topic Favorites products
Almost everything is possible via css custom command, learn here how to add your own css command.
Then, step by step, you have to keep the button container, but remove the content to replace it by your required image.
// Remove content .container_class_html .element_class { display: none; } // Add your image .container_class_html { background-image: url(YourWebsite/folder/ImageUrl.png) }
Hope this will help you to achieved what you need.
Last edit: 4 years 6 months ago by Philip.
4 years 6 months ago #340279 by komir
I have add
// Remove content
.container_hikabtn hikawishlist .element_class {
display: none;
// Add your image
.container_hikabtn hikawishlist {
background-image: url( freepngimg.com/download/web_design/65470...like-png-file-hd.png )
but nothing is changed :unsure:
4 years 6 months ago #340284 by nicolas
Philippe's code requires that you change the CSS classes in his code with the classes of the elements you want to affect. Just copy/pasting what he provided won't work.
And in this case, what he proposed won't work anyways because the button of the wishlist doesn't have a container div.
I think there is a much simpler solution though. You can just add a translation override like this:
ADD_TO_WISHLIST="<img src='https://freepngimg.com/download/web_design/65470-emoticon-button-smiley-facebook-like-png-file-hd.png' />"
4 years 6 months ago - 4 years 6 months ago #340301 by komir
Thank you that is essayer solution and working as expected ;)
How to add that button on the top position, above the product image, now it is on the bottom under quantity?
Last edit: 4 years 6 months ago by komir.
4 years 6 months ago #340305 by nicolas
You can do that with CSS code. For example:
.hikawishlist{ position: relative; top: -432px; left: -98px; }
Time to create page: 0.251 seconds
