Google Products Description using tabs
- rayjbarrett
3 years 10 months ago #347839
by rayjbarrett
Google Products Description using tabs was created by rayjbarrett
I use tabs in my products' descriptions. See this example:
www.telementalhealthtraining.com/courses...ow-online-self-study
However, this means that Google Products is displaying the list to tabs' titles in the beginning of the description of the products. This looks very bad. See this screenshot: tinyurl.com/2pad555n
Is there a solution for this?
3 years 10 months ago #347844
Replied by nicolas on topic Google Products Description using tabs
In the settings of the Google Products plugin, you have a setting "short description". You can select "use meta description" to provide an alternative description for your products in the "meta description" field of each product. This field is also used for the corresponding meta tag on the product details page so it's good to have it filled for SEO purposes.
