Error in products listing menu
3 years 2 months ago #354141 by jalal.amir
-- HikaShop version -- : 4.7.5
-- Joomla version -- : 4.3.3
-- PHP version -- : 8.1
-- Error-message(debug-mod must be tuned on) -- : An 0 error occured during your request.
call to undefined function parse_ini_file()
Hello
I create menu to display products listing.
When clicking on the menu, the following error is displayed:
I changed template and php version but the problem was not solved.
3 years 2 months ago #354144 by nicolas
The PHP function parse_ini_file is a standard function of PHP and is supposed to be always available on any hosting.
The error you have indicates that the system administrator has disabled its use. As far as I know, there is no valid reason to do that.
It might be an error in the server setup.
Someone else reported the same issue in the past here :
wordpress.org/support/topic/exception-wh...from-php-7-4-to-8-0/
You'll have to contact your hosting support for help. That function not being available on your hosting is not normal.
Time to create page: 0.144 seconds
