Cart button is not showing anywhere (Product listing and product details page)
3 years 2 months ago - 3 years 2 months ago #354593
by reim95
Cart button is not showing anywhere (Product listing and product details page) was created by reim95
spitz-teufelsdesign.com
-- HikaShop version -- : 4.7.5
-- Joomla version -- : 4.3.3
-- PHP version -- : 8.1.21
-- Browser(s) name and version -- : Google Chrome 106.0.5249.119
-- Error-message(debug-mod must be tuned on) -- : Cart Button is not showing anywhere in my website (Product list or Product details)
Recently I migrated or upgraded my started version to business and intended to run a full featured web shop where I'm facing a huge problem with cart option.
I set everything perfectly and tried all the way I know but haven't any luck yet. Still now Cart button is not showing on any product and also I can't test cart and checkout related features. I'm expecting a quick response from your side please.
I enabled the debug option and there is not any important error related to HikaShop.
Last edit: 3 years 2 months ago by reim95. Reason: Type mistake
3 years 2 months ago #354599
Replied by nicolas on topic Cart button is not showing anywhere (Product listing and product details page)
There are several ways to remove the add to cart buttons:
- First, you have the "catalogue mode" setting, under the "Features" tab of the HikaShop configuration page. Check that this option is turned off.
- Second, if the product has a stock of 0, the add to cart button won't appear either. So check the "quantity" setting of your products.
- Third, if the price of the product is 0, and the "display add to cart button for free products" setting of the HikaShop configuration is turned off, the add to cart button won't appear.
- Fourth, if the "available from/to" settings of the product are set such as the start date is in the future, or the end date is in the past, the add to cart button won't appear.
If it would be 2 or 4, a message should appear on the product page, and if it would be 3, the price should not appear on the product page. I checked the product page of a product on your website, and I think it's probably the first reason. So please check that setting.
