Issue ith canonical URLs
3 years 4 weeks ago #355856 by nicolas
Replied by nicolas on topic Issue ith canonical URLs
Then I'm not sure what the change should be. It would require some debugging of the Language Filter plugin.
3 years 3 weeks ago #355894 by Sandra74
Replied by Sandra74 on topic Issue ith canonical URLs
There's something that is confusing to me.
The canonical URLs work fine for one collection and not for the others. I can't understand why it's not consistent.
For the moment, as a temporary solution I disabled the "alternate" feature in the language filter plugin to have the canonical URLs displayed in the source code.
3 years 3 weeks ago #355909 by Sandra74
Me again.
I have another site in 2 languages and on this one no problem, canonical URLs work and alternate URL too. So it should be something within the site which prevents things to work as expected
Sandra
3 years 2 weeks ago #356073 by Sandra74
I just noticed another issue with canonical URLs.
Even with Add Alternate Meta Tags on NO, the canonical URLs are not correct.
In the default language (US), it's ok, but not in French, the canonical URL remains the same as you can see for example on this page:
rolex.jewelrygoldfinger.com/fr/collection/yacht-master
The canonical URL should contain "fr" but it doesn"t. In fact it displays the canonical URL set up on the main screen and not the one set up in the French screen,
I'm really not sure it's an issue with the plugin.
I really need to be able to solve this issue but I have no clue how.
Thanks in advance for your help.
Sandra
3 years 2 weeks ago #356086 by nicolas
Indeed, I can see the translation of the canonical URL is ignored. I've made a patch which should fix the problem.
Download again the install package of the 5.0.0 and install it on your website and you'll get the patch.
3 years 2 weeks ago #356088 by Sandra74
Thanks a lot Nicolas. It works, 'fr' is now in the canonical URL.
I also noticed something (no clue if it can be of any help):
- Add Alternate Meta Tags on YES
- Remove URL Language Code on NO
For the default language (US), it's all good, canonical + alternate
In the second language (so here French), canonical is missing
Sandra
3 years 2 weeks ago #356093 by nicolas
Isn't that the same problem we were talking about since the beginning of this thread ?
3 years 2 weeks ago #356133 by Sandra74
Yes, it's part of the problem.
3 years 2 weeks ago #356138 by nicolas
Well, if you can provide a backend and a FTP access, I can have a deeper look into it and maybe try to understand what can be done to fix the problem. If we provide a correct patch to the Joomla project, they'll be more reactive and integrate it in Joomla.
3 years 2 weeks ago #356146 by Sandra74
With pleasure!
3 years 2 weeks ago #356157 by nicolas
I think I found the solution.
Adding the line:
if($i !== $this->current_lang)
before the line:
$doc->addHeadLink($server . $language->link, 'alternate', 'rel', ['hreflang' => $i]);
in the file /plugins/system/languagefilter/src/Extension/LanguageFilter.php seems to do the job.
The following user(s) said Thank You: HALVAM, Sandra74
3 years 2 weeks ago #356181 by Sandra74
You rock!
It works like a charm.
Thank you so much!
Sandra
