variants title not work properly
2 years 9 months ago - 2 years 9 months ago #357391 by Bender
If you create a product and add variants to it, a drop-down list will appear on the product page to select an variants.
When you select an variants, the title of the page changes, which consists of the product name and the name of the variants.
But when you first launch the page, although the default variants is selected, the selected variants is not displayed, but only the product name is displayed.
How to fix it ?
For example product name = good_product, varian 1 = 1, 2 = 2, 3 = 3
first launch of page is good_product, after selector good_product: 1, good_product: 2, good_product: 3
Last edit: 2 years 9 months ago by Bender.
2 years 9 months ago #357402 by nicolas
By default, when you install HikaShop, the setting "Characteristics dynamic display" setting is activated. With it, no variant is pre selected on the product page.
With that setting turned off, the default variant is indeed pre selected.
Now, even if some cases, merchants don't necessarily want to display the variant name next to the product name unless the user selects something else (for example, if you have a variant "please select" create and set as default.
So it's not really a bug, but a compromise we made for the name to display like that.
However, you can easily change the behavior.
Edit the file show_default via the menu Display>Views and change the line:
if(hikashop_getCID('product_id') != $this->element->product_id && isset($this->element->main->product_name))
if(false)
and it should work like you want it to.
Time to create page: 0.177 seconds
