Multi Part Product
2 years 5 months ago #361079 by kenny_robb
-- HikaShop version -- : 5.0.4
-- Joomla version -- : 4.4.4
-- PHP version -- : 8.3
Not sure if this is the right place for this query.
I have a load of single products and want to create a special where people can pick 6 and have then specially packed etc etc this special product I would like to be able to check that they have ordered 6 items before placing the order....
1. Is this possible
2. Where would I find out how to do it?
K
2 years 5 months ago #361081 by nicolas
Replied by nicolas on topic Multi Part Product
You could create a characteristic with one product name per value.
Then, create an unpublished category.
In that category, create 6 products, with that characteristic selected in the "characteristics" setting, and then all the variants added under the variants tab.
Then, you could create a "multi part product" and add these 6 products in its "options" setting.
That way, on the details page of that multi part product on the frontend, you'll have 6 dropdowns where the customer will be able to select a product in each.
Make sure that the "group options with product" setting is activated in the HikaShop configuration.
That way, when the user adds to the cart the multi part product, it will also add the 6 selected options together with it.
2 years 5 months ago #361085 by kenny_robb
Replied by kenny_robb on topic Multi Part Product
I shall give that a go and see how I get on....thank you
