Product desctriprion / Read more
2 years 5 months ago #361380
by Pajerchin
Product desctriprion / Read more was created by Pajerchin
-- HikaShop version -- : 5.0.4
-- Joomla version -- : 5.1.1
MENU -> Hikashop->Categories listing
THIS IS OK:
THIS IS NOT OK:
Would you be so kind to help me with this, please?
THIS IS OK:
- Layout type: Image and description -> the Description of the category -> There is displayed text as far "Read more" flag.
- After the category is open - there is displayed whole text
THIS IS NOT OK:
- Products options -> Table
- For the products listed in category - as Description of the product is listed whole description text
- I need to be displayed text as far "Read more" flag. ...and whole text should be displayed after the "product details" is open
2 years 5 months ago - 2 years 5 months ago #361381
by Philip
Replied by Philip on topic Product desctriprion / Read more
Go in the menu Display => Views and edit the file "listing_img_title" (or relative selected Layout type) of the view "product/listing_img_title". There add a link like that:
Then, if required in the Languages tab of the configuration, edit your translation files and add a override like that:
MY_READ_MORE="Read more" or else...
<a href="<?php echo $link;?>"><?php echo JText::_('MY_READ_MORE'); ?></a>
Last edit: 2 years 5 months ago by Philip.
2 years 5 months ago #361393
by Pajerchin
Replied by Pajerchin on topic Product desctriprion / Read more
Hello Philip,
Probably I not clearly explained what I need
How it works now
Categories list
After you click to Category 1 – then you see:
BUT - the same - with products - looks like a bug
Categories list
It should look like that
Categories list
How it works now
Categories list
- Category 1
Description of the Category 1 Description of the Category 1 Description of the Category 1 Description of the Category 1 Description of the Category 1 Description of the Category 1 - Category 2
Description of the Category 2 Description of the Category 2 Description of the Category 2 Description of the Category 2 Description of the Category 2 Description of the Category 2
- Category 1
....................................................... (readmore )
Detailed description of the Category 1 Detailed description of the Category 1 Detailed description of the Category 1 Detailed description of the Category 1 Detailed description of the Category 1 Detailed description of the Category 1
Categories list
- Category 1
Description of the Category 1 Description of the Category 1 Description of the Category 1 Description of the Category 1 Description of the Category 1 Description of the Category 1 - Product 1
Description of the product 1 Description of the product 1 Description of the product 1 Description of the product 1 Description of the product 1 Description of the product 1 Description of the product 1
Detailed description of the product 1 Detailed description of the product 1 Detailed description of the product 1 Detailed description of the product 1 Detailed description of the product 1 Detailed description of the product 1 Detailed description of the product 1 Detailed description of the product 1 Detailed description of the product 1
Categories list
- Category 1
2 years 5 months ago #361397
Replied by nicolas on topic Product desctriprion / Read more
From what you wrote before, I understand that you're using the "table" layout for your products listing.
However, the table layout doesn't display the description of the product at all by default.
If you switch to "div" with the "image and description" item layout, you should see that the description of the product displays up to the read more tag, like for the description of the category.
What all of this means is that I think you (or someone on your end or your template provider) must have customized the product / listing_table view file in order to add the display of the description, but instead basing himself on the code in product / listing_img_description in order to have the description cut at the read more tag, you used some other code.
So you'll have to edit the product / listing_table view file via the menu Display>Views in order to look at the code and correct the code for the description display based on what we have by the product / listing_img_description view file.
The following user(s) said Thank You: Pajerchin
