remove frame around products
2 years 2 days ago #364225
by Arqitect
remove frame around products was created by Arqitect
-- HikaShop version -- : 5.1.1
-- Joomla version -- : 5.1.4
-- PHP version -- : 7
-- Browser(s) name and version -- : Chrome 128.0.6613.120
I can not locate where the frame is around the items, for some reason there is a white frame or table that is located around every single item in the store, I have tried removing them and setting the size to 0 and everything still they persist how can these be removed to make everything look nice and clean?
2 years 2 days ago #364228
Replied by nicolas on topic remove frame around products
This white frame on your website comes from the CSS code:
in the file /templates/et_ads/css/hikashop.css of your Joomla template.
I'm not sure why the template provider has added this CSS code to his template.
I would recommend contacting the template provider to check with them what they recommend.
body.com-hikashop.layout-listing .hikashop_product {
border: 1px solid #fafafa;
padding-bottom: 20px;
