products not showing from Category
1 year 8 months ago #365935 by Harlequin
-- HikaShop version -- : 5.1.5
-- Joomla version -- : 5.2.4
-- PHP version -- : 8.2.26
-- Browser(s) name and version -- : Firefox 135.0.1 (aarch64)
Hi, I have upgraded my system from Joomla3 to J5. Using Cassiopeia. Hikashop is working correctly on my live site: aienglish.co.uk/taab/
Please see the accordion menu on the left.products are displayed when the sub category (level2) is clicked.
I have the J5 updated site on MAMP V.7.7.2 the categories are showing correctly but no product is shown when the sub category is clicked. A 404 page not found message is shown. Hikashop content all looks correct from the back end.
I have tried to rebuild the menus
I have checked the settings between the old and the new site.
I have tried making a new module but have the same issue.
Please can you advise where to look and how to try ans solve this. I have spent a week going round and round in circles!
Thank you
Tony
1 year 8 months ago #365937 by nicolas
Are the URLs of the categories in the left module the same as on your live website ?
Do you still have a menu item with the alias "product-shop" ?
Could you activate the debug setting of the Joomla configuration and access the 404 error page of a category ? Could you provide a screenshot of what you see ?
1 year 8 months ago #365982 by Harlequin
Hi Nicolas, thanks for the help
Yes the URLs appear to match
Please see comments after each match
aienglish.co.uk/taab/product-shop/category/15006-buffers
Live site = works
https://taab1:8890/taab/product-shop/category/15006-buffers
Local site = 404 error
aienglish.co.uk/taab/product-shop/catego...c-wipes-and-cleaners
Live site = works
https://taab1:8890/taab/product-shop/category/15446-anti-static-wipes-and-cleaners
Live site from top Nav = works
https://taab1:8890/index.php/product-shop
Local site from top Nav = works
aienglish.co.uk/taab/product-shop/hikash...r-categories-listing
https://taab1:8890/index.php/product-shop/hikashop-menu-for-categories-listing
Sub category (from top nav category=
https://taab1:8890/taab/product-shop/category/beakers-ptfe
aienglish.co.uk/taab/product-shop/category/beakers-ptfe
Live site = works
I have enabled the error reporting for this first larval category
https://taab1:8890/taab/product-shop/category/14984-chemicals
Error message as attached image
Tony
1 year 8 months ago #365987 by nicolas
Do you have some kind of SEF extension, like SH404SEF ( 4SEF ), or JomSEF, or others ?
Something strange with your results is that even on the live website, some URLs don't have the id of the category in the URL (like the beakers ptfe). Normally, either all of them should have the id or none of them.
This indicates that you probably activated the "force canonical URLs on listings" setting of the HikaShop configuration:
www.hikashop.com/support/documentation/5...ig.html#features_sef
And in that case, the URL used is the "canonical URL" that you configured in the settings of the category, even if the URL there is invalid. And so, if you setup a category with a canonical URL using the alias of a menu item, and that something changes with that menu item or with some SEF settings, the URL would then generate a 404 error.
For example, I can see that you have the "category SEF name" setting set to "category" on your live website. If you changed that setting on your local website, then all the canonical URLs of the categories with that "category" SEF name would be invalid instantly.
Could you provide a screenshot of the "SEF" section of the HikaShop configuration page on your local website ?
What if you empty the "canonical URL" of a category and then refresh your frontend, and access that category ? What URL is now used ? Do you still have the 404 error ?
1 year 8 months ago #365988 by Harlequin
Hi Nicolas
I think you may have found the issue..
I do not think I have any SEF extension (at least not deliberately)
I have removed the canonical URLS as suggested and these changed items:
Category > sub-category > product. These now all work
I have attached the screen shot for the live site and for the local site.
Thanks for the quick reply
Tony
1 year 8 months ago #365989 by Harlequin
Hi Nicolas
I also included a screen shot of the local site
Product shop
> Product page.
error message.
Tony
1 year 8 months ago #365993 by nicolas
Great, we're moving forward.
For the product page, do you also have 404 errors for all the products ?
Do you have canonical URLs for all the products too ? If so, what if you empty the canonical URL of the product ? Does it help ?
1 year 8 months ago #365998 by Harlequin
Thanks for the update.
The product-page is essentially the same as the product listing page.
It would seem that this "product-page" is miss-configured - image attached.
Its probably easier to delete this menu item?
When the "product shop" top menu on the live and local site is activated
Product shop/categories listing
The categories are shown but below that there are all the products showing. This is confusing can you help on this. do you need the logon for the live site?
Also on the local site when I click on the accordion menu (Left hand side) "Chemicals" I get a list of categories shown in the main content with images. This should be like the live site and only open the accordion to the sub menu. where can I change this please.
Sorry for all the questions, hopefully this should start to resolve this.
Many thanks
1 year 8 months ago #365999 by nicolas
- Indeed, you need to select a product in the "select a product" setting. Without any product selected, it's normal that you get that error.-
You probably don't need this menu item. So yes, I think you can just delete it.
- Edit the settings of the "Categories listing" menu item via the Joomla menu manager. There, under the "products options" tab, change the "sub elements filter" setting to "direct sub elements". That should remove the products from the categories listing page.
- The accordion system on the left side is made with the Accordion CK module apparently. If the accordion doesn't open when you click on the name of a category, then it's probably something to do with the settings of that module. I'm afraid you'll have to check with the developer of that module for this issue as I don't know how it's made.
The following user(s) said Thank You: Harlequin
1 year 8 months ago #366007 by Harlequin
Hi Nicolas
A big thank you. That has sorted most issues. I will work through and hopefully resolve the outstanding myself.
Excellent support as always
Time to create page: 0.112 seconds
