Mini cart problem in homepage
15 years 7 months ago #13104 by webarts
hello,
we use the essential version of your component in this site www.webarts.com.cy/demo/e-shop/
when the user has some items in the cart while his is in the homepage and click on the mini cart at the top right corner, he cant go to check out the page is just refresh at the homepage.
what is going wrong?
15 years 7 months ago #13119 by nicolas
You need to select a menu in the option "force a menu on checkout" in the config under the tab checkout, otherwise, the checkout will be displayed on the same menu it comes from.
