- Thank you received: 36
URL not match help me please please
14 years 8 months ago #41296
by lhumdin
URL not match help me please please was created by lhumdin
please to link
www.mom2kiddy.com/%E0%B8%8A%E0%B8%B1%E0%...ct/listing.html.html
If you click on the catalog every item in this category, you will see the error of the url.
Now, please tell and help me a lot.
14 years 8 months ago #41297
by lhumdin
Replied by lhumdin on topic Re: URL not match help me please please
i use sh404sef
why have .html.html (2)
14 years 8 months ago #41448
Replied by nicolas on topic Re: URL not match help me please please
There is an option in sh404sef to append .html at the end of URLs. If you deactivate it, it might work.
You should ask sh404sef support regarding the fact that you get .html appended twice to the URL. That's not normal.
But I don't see why it would come from HikaShop.
14 years 8 months ago #41482
by lhumdin
But since it is only one component hikashop.
I have tried several other test component.
I noticed that the url hikashop may not support Thai language 100%.
14 years 8 months ago #41619
I must say that we didn't test sh404sef and HikaShop with thai language.
I don't see why it wouldn't work though.
Maybe you could try to switch the handler for HikaShop to the router file. That can be done here:
www.yireo.com/images/stories/magebridge/...4sef_bycomponent.png
14 years 8 months ago #41626
by lhumdin
If you test it first. You will understand the problem.
This problem occurs when using sh404sef.
The problems were.
1 url checkout.
2. Url certain items.
But I have discovered a way to solve the problem.
Is to be disabled. Some functions of hikashop.
Like to work with some of the authorization. Are complex. And support url thai.
The problems were.
1 url checkout.
14 years 8 months ago #41627
by lhumdin
If you are permitting the subject distinguishes my thai language forum to help answer questions for the Thai people. I use hikashop.
And a bug report for the url, which I found to be caused by anything.
14 years 8 months ago #41628
by lhumdin
I also confirm that hikashop is an extension for joomla.
If only working on seo and seo in English or a function of jomla or
Latest joomla module social problems of each of the scripts. Another cause problems.
But I'm willing to give advice. The solution to all the people. The Thai people. Strongly.
Thank you.
Thank you.
14 years 8 months ago #41802
Thank you for your offer. Yes we can put up a thai forum if someone can answer on it. I've created the thai forum and set you moderator.
14 years 8 months ago #41834
by lhumdin
Thanks and I look forward to bringing the matter. I have the share component, as hikashop to know more.
The system is easy to use and really good.
