Re: Problem after registering
14 years 8 months ago #42576
by hyrms
Re: Problem after registering was created by hyrms
I have the same problem. Prices display correctly, but when logged in it shows then net price and also the rest of the order process is all net without taxes. I cant' find 'Tax rules' in Configuration/Sytem/taxes...?
I checked my Zone Setting and the Zone is set to 'Countries'.
14 years 8 months ago #42577
Replied by nicolas on topic Re: Problem after registering
The same problem ? Could you explain more ?
Maybe post some screenshots of your configuration ?
14 years 8 months ago #42583
by hyrms
Replied by hyrms on topic Re: Problem after registering
I was referring to "Problem after registering". All prices are displayed correctly on the products pages. When I add products to cart all works fine. Then when I register and sign in, the prices are shown without taxes. The user however has selected correctly the country which applies to the zone in his address.
14 years 8 months ago #42719
Could you do a screenshot of your tax rules ?
By tax rules I mean the entries in the System->Taxes listing.
14 years 8 months ago #42901
by hyrms
Screenshots attached
14 years 8 months ago #42977
So the way you configured it, the tax will only be applied if:
- the user didn't enter anything for the company name field of his address (or if that field is not published)
- the user address is not in chile
- the tax category of the product is not chile
Since you say that you see the taxes before registering, it only leaves the two first options.
So I would recommend to check that.
