- Thank you received: 1
Purchase without registration does not work
-- Joomla version -- : 2.5.16
-- PHP version -- : 5.2.17
-- Browser(s) name and version -- : Mozilla Firefox 25.0
Hi, with version 2.2.1 of HikaShop, I can make online purchases in my shop without registration. I have enabled these options:
- HikaShop> System> Configure> Complete Purchase> Registration and Access:
- Access: No
- Data: No Registration
- Show confirmation email field: No
The process works well and users can buy without having to register or log into the system. No need to put any user name or password only address, shipping and payment form and ready.
However, a few days ago HikaShop upgraded to version 2.2.2, and it turns out I have listed options have changed slightly, and now when I make a purchase without registration, does not work and shows me a message that says something about not can continue if no password is entered correctly.
Therefore, I can not make a purchase without registration. Is it a bug of the new version or is there any way to configure it to allow users to purchase without registering?
Thanks, greetings.
- Thank you received: 1778
We have made some change for the registration option through the 2.2.2 version. Firstly, can you show me through some screenshots, how did you configured your page "Hikashop->System->Configuration->Checkout" ?
I also facing same problem, I want to checkout and make the payment without login, without register in to the show,
I just want to checkout just putting the address only, but i can't configure out for it.
Please be help. here I will provide the screen shot of my configuration setting as well.
To do it, you'll have to use the Registration / Display method for registration options, but as you can see on you screenshot, you'll need an Hikashop commercial version.
Mohamed Thelji wrote: Hi,
Commercial Version mean Business or Essential ? Which one ?
Do I need to buy Essential and Business Version? Is it?
I don't get what you mean ?
And if Yes, Why I need both ? should enough with Business or Essential ?
Thanks you.
Now I already get Business version, but I can't figure out the way that what I want.
I want to check out without login but I want to keyin the contact information such Address, Phone No so that shop can contact for delivery.
Could you please advice me.
nicolas wrote: No, both of them have that capability. Only buy one of them.
I want to check out without login but I want to keyin the contact information / Customer Information such as Address, Phone No, so that shop can contact for delivery and sending the Invoice.
- Go to "Hikashop->System->Configuration->Checkout"
- Set the "Display method for registration" option to All in one page
- Set the "Registration" option to Guest
In Configuration > Checkout, in the checkout workflow you need the steps "login - address" to display the desired custom fields , for the option "Display method for registration " you have to select "All in one page" and for the option "Registration" select "Guest".
Then you can add/edit custom fields via the menu Display > Custom fields.
I deleted all the products and I have a new import and the same thing keeps happening.
A greeting.
Do you have set an access level on the prices ?
If it is, if you don't set any price for the public it will display the product as free.
You need to set a price for public if you allow the guests to see the products.
I probably found out from where the problem was coming, you'll just have to :
- Edit the "\components\com_hikashop\views\user\view.html.php" file
- Change these lines :
3by400, Inc.
3by400.com
Websites that Work, Marketing that Matters
