message "cart is empty" while cart has products
13 years 7 hours ago #134229 by raviry
-- HikaShop version -- : 2.2.2.
-- Joomla version -- : 3.2
-- PHP version -- : 5.3
While trying to checkout, Hikashop shows message "The cart is empty" while the cart has products in it.
in the above situation, products can not be deleted, also cannot be added to the cart.
13 years 6 hours ago #134237 by Mohamed Thelji
That's probably coming from a cache issue, can you disable the Joomla cache, and clear it ? You'll also have to disable it in the joomla config, and unpublish the cache plugin. Also can you clear your browser's cache or try it with another browser ?
13 years 6 hours ago #134244 by raviry
Hello Thelji,
System - Cache plugin is disabled. also I have cleared the cache.
My Cart retaining period is 50 min
This happens in the idle time. Like I added a product in the cart and idle for some time(no activity in the site). After some time, when I try to checkout it shows the message.
13 years 1 hour ago #134303 by Xavier
Have you set limits on you products ?
12 years 11 months ago #134826 by otx
I have the same situation, but only with WebKit based browsers. If I add something to the cart then navigate to the Home page, cart displays the Cart is empty message, but if I add something to it then I have all the products in the cart. On the Home page we have the empty message. We hade tried with Hikashop 2.1 and 2.2.2 Business but it's the same. Cache is disabled, but it's the same with enabled, doesn't matter. What could be wrong?
The url: www.vitaking.ro Add something in the cart, then click on the site logo, you will have the empty cart message. Click on a product page: you have the product in the cart. Why?
Please help.
Dezso Markon,
vitaking.ro
12 years 11 months ago #134947 by Xavier
This is working fine on, for example, firefox ?
Are you sure that you don't have any cache, like the system cache plugin, or some cache in the template, etc ?
I just tried on Chrome which is a webkit browser, and I don't had the problem. The cart was always displaying that I had one item in it.
12 years 11 months ago #134968 by otx
Dear Xavier,
No it doesn't work on other browsers. It was my mistake. I also found out that I had the system cache plugin enabled, even if the cache in the global configuration wasn't set. I have tried all the suggestions regarding using other cache solutions for Joomla, but unfortunately none of them works with my site. Everything is fine until one navigates to the home page where the cart displays the empty cart message. Other then this, is working fine with Joomla 3.2 and Hikashop 2.2.2 Business. I'm still looking for solutions, as the site is much faster with cache than without.
Dezso Markon
12 years 11 months ago #134987 by Mohamed Thelji
I just tested it and it's working fine for me.
