Checkout and module not showing
12 years 9 months ago #145429 by rastapucioso
-- url of the page with the problem -- : www.fireforest.it/index.php?option=com_h...t=listing&Itemid=239
-- HikaShop version -- :HikaShop Starter 2.3.0
-- Joomla version -- : 3.0
-- PHP version -- : 5.3.2
-- Browser(s) name and version -- : Google chrome
I ve some problems because if I use any hikashop menu item the website look like loading and loading and loading loop.
If I use an article with inside the joomla content module look like it shows the products but i cannot checkout and go to the login page.
Have I done some mistakes or there is some problems with the template's compatibility
12 years 9 months ago - 12 years 9 months ago #145463 by lionel75
you use ekho templates and it is very well documented. the custom Layout of nivo slider is very nice ( good way to learn more ) .
See the the capture screen for some clues about error , Perhaps some links have change for ressources ( javascript ) .
regard's
Last edit: 12 years 9 months ago by lionel75.
The following user(s) said Thank You: rastapucioso
12 years 9 months ago #145579 by rastapucioso
I tried to use jqueryeasy but the problems remains the same.......
12 years 9 months ago - 12 years 9 months ago #145604 by lionel75
in the page there is a link to
ajax.googleapis.com/ajax/libs/jqueryui/1.9/jquery-ui.min.js
This url don't exist !!!
in jquery ui blog the url seem formated like x.x.x
so 1.9 should be write 1.9.0
the url should be
ajax.googleapis.com/ajax/libs/jqueryui/1.9.0/jquery-ui.js
but the last version 1.9.x is for x = 2
verify that all ressources files location exist ( css php html js)
12 years 9 months ago #145607 by lionel75
it the problem come from one extension try to desactivate one extension one by one to find where the problem here .
by extension i mean module or plugin or component .....
If al lthe other page work find which change occur in the problem page.
hope it ll help
