Minimal order amount problem
12 years 8 months ago #147315
by shpuser
Minimal order amount problem was created by shpuser
-- Joomla version -- : 2.5
on all shipping and payment methods the minimum price is set to 39, but if i add something under 39€ and go to cart then the message is: the minimum order amount.... is 10€, but 10 isn't true. Any idea?
- Thank you received: 1778
12 years 8 months ago #147332
by Mohamed Thelji
Replied by Mohamed Thelji on topic Minimal order amount problem
I just tested it on my end and the messages that you should have are :
- "The total of your order is too low for all the possible shipping methods"
- "No payment methods found"
1. Did you done some customization through your language file ?
2. A good thing can be to download the last Hikashop version through our website (2.3.0), install it, and test it again.
12 years 8 months ago #147454
by shpuser
Replied by shpuser on topic Minimal order amount problem
i translated it from other language and there was "10" hardcoded, now works everything, thanke you
