When I Click add to cart..
- aaroncartwright
12 years 7 months ago #151200
by aaroncartwright
When I Click add to cart.. was created by aaroncartwright
Most likey a very simple problem, but I'v only just started using HikaShop so bare with me!
When I Click add to cart, it adds the product and then takes me straight to checkout, is there a way I can click add to cart.. and then click continue shopping? Im guessing it most likely a simple tick box somewhere but I can't find it for the life of me!
Help guys! >_<
Aaron
Help guys! >_<
Aaron
- Thank you received: 1778
12 years 7 months ago #151212
by Mohamed Thelji
Replied by Mohamed Thelji on topic When I Click add to cart..
Hello Aaron,
The solution will be to set the "After a product is added to the cart" option to Stay and display a popup notice through "Hikashop->System->Configuration->Main".
The following user(s) said Thank You: dashmalta
12 years 7 months ago #152616
by dashmalta
Replied by dashmalta on topic When I Click add to cart..
how can I edit the popup notice? I want to change the size and colour of the "continue shopping" button please
12 years 7 months ago #152664
by Xavier
Replied by Xavier on topic When I Click add to cart..
You have to edit the view "checkout / notice" via the menu Display > Views and you can too add your own css properties to customize it too.
Here is a tutorial to help you for these modifications:
