voucher does not work
12 years 6 months ago #153121 by sel
voucher does not work was created by sel
-Hello,
I created a good discount on a category to the achievement of 40 €.
This discount is not applied based on the value I set (40 €).
Many times the bonus is applied to lesser amounts.
Can you give me information what's wrong? thank you
12 years 6 months ago #153142 by Jerome
Replied by Jerome on topic voucher does not work
Did you created a discount or a coupon ?
Please provide a screenshot of your discount configuration.
12 years 6 months ago #153225 by sel
Replied by sel on topic voucher does not work
hello, I created a coupon but does not work
12 years 6 months ago #153229 by Jerome
So you have to create a "discount", not a "coupon".
A coupon is a "coupon code", it is not a discount.
12 years 6 months ago #153297 by sel
HELLO
thank you for your reply but creating a DISCOUNT do not have the ability to enter a maximum amount (like 40 €) beyond which the discount is applied
12 years 6 months ago #153302 by sel
I'm sorry but I still wish that it worked out this form attached with the settings inserit: coupon amount, the category to which you apply the coupon, limit to apply the coupon.
unfortunately is not complied with the minimum liminite (40 €) set
12 years 6 months ago #153300 by Jerome
Ok I see, you want an auto-loaded coupon, not a discount.
Please provide
- a link to your website
- some information about your Joomla and your HikaShop versions
- some details about how accessing the products which are in the targeted category for your auto loaded coupon.
- a screenshot of your checkout workflow
Please note that a coupon will be loaded when the step "coupon" is in your checkout workflow
Please note that you put a restriction on the address, the customer should be logged and should use an address in Italy.
12 years 6 months ago #153366 by sel
The website link is: www.sigarettaelettronica.milano.it
- Version HikaShop: Business: 2.3.0
- Version Joomla: 2.5.19 Stable
Products in category:
- El Toro
- Papillon Organic
- EBaron Lab
- The Cellar
- Base EL TORO
thanks for everything
12 years 6 months ago #153367 by sel
attention to aggevolare I deleted the address Italy
12 years 6 months ago #153525 by Mohamed Thelji
I just tested it through your website and it seems to be working fine, when my order price is under 40€, no coupon is added, but when my order price is bigger than 40€ the coupon is auto-loaded :
12 years 6 months ago #153526 by Mohamed Thelji
12 years 6 months ago #153639 by sel
Hello, thank you for your answer and proof that you did.
I have to tell you that but it is not always as it should be in the form does not always work properly
I attach a photo as you see the coupon is activated even under 40 €
12 years 6 months ago #153640 by sel
I have to tell you that but it is not always as it should be the module does not always work properly
I attach a photo as you see the coupon is activated even below 40 €
12 years 6 months ago #154315 by Mohamed Thelji
Hello and sorry for the late reply,
That's maybe a cache issue, can you disable the Joomla cache, and clear it ? You'll also have to disable it in the joomla config, and unpublish the cache plugin. Also can you clear your browser's cache and try it again ?
