- Thank you received: 4
features how-to for cart & checkout?
- olivnewton
cart module:
1. "show title" is YES but its not showing (maybe because "mini cart" is YES?)
2. hide cart module if empty
checkout:
i managed to hide cart on checkout (not an easy task, but it worked)
created 2 menus:
- hikashop > product
- hikashop > checkout (this info was missing in mohameds description: www.hikashop.com/forum/checkout/863039-n...-be-easy.html#129157 )
- in "Hikashop->System->Configuration->'Checkout'"
used the "Force a menu on the checkout" option to one of your menu (= in my case "checkout")
- in the "Module Assignment" of my cart module
set option to "Only on the pages selected"
un-checked the menu that your have set through the "Force a menu on the checkout" option (= in my case "checkout")
but now in the adress bar i get the following URLs:
myshop.com/checkout/checkout/
myshop.com/checkout/checkout/task-step/step-0...x
1. is it possible to get rid of the double "checkout"?
2. is it possible to add custom text for "task-step" and "step-0 ... x"?
best regards
1. The title should be displayed, don't you have a css rules which is hiding the title ?
2. This will require some JavaScript, check if the element is empty via javascript and hide the parent.
1. By changing the menu name, you can avoid to have it twice. Or by using sef component.
2. This will require modifications in the controllers, etc so core file. It's not recommended.
- olivnewton
1. no there is no such css rule and also no template override. here is the module code, as you can see no title in there:
2. tried just now, even if cart is empty, the element is not, because there appears the message "cart is empty" inside of it...
any idea?
checkout 1. & 2. ... i see, would be nice though to change (2) via language files?
Also there appeared another issue / question today:
- we are trying to add direct custom "add to cart" links from other non-hikashop sections of the website
- so far we could figure out how to do this from within hikashop sections:
- what scripts do i have to include in order to use the js outside the shop?
- or is there maybe an even better way?
best regards
1.1 - The titles of the modules are displayed by Joomla. Please check the configuration of the Joomla module.
I know that there was a bug in an old version of HikaShop ; you didn't provide yours so I can't know if it is linked or not.
1.2 - I am sorry but I don't understand, I don't visualize it.
2.2 - It is not possible to use the language file for that.
3.1 - The javascript function is defined by HIkaShop and works only in HikaShop.
If you want to add products using an url, you can add the "updatecart". In the backend, while editing a product just click on the button "Add to cart link" and it will provide you the current link for the specific product.
- olivnewton
1. in joomla config "show title" is set to yes and i use no override
2. i will try to explain: in order to hide the empty cart module, you suggested to check via javascript if the element is empty and then hide the parent... but, the element is not empty, it contains the text "cart is empty":
3. will try the updatecart link
thanks
- olivnewton
Removing the cart module when the cart is empty doesn't involve any coding.
Just do a translation override of the cart empty message ( hikashop.com/download/languages.html#modify ) in order to empty the text. If no text is added, the module itself won't add its own HTML, and if it doesn't, the CMS/template won't display the chrome around the module either.
- olivnewton
- olivnewton
i even just created a custom module style (in modules.php) and selected this in "cart module" > "advanced" > "module style"
...still no luck...
If you don't see the title of the module while you activated the option of the module to display it, it probably means that you configured the module to display in a position of the template where the title is not displayed for modules.
- olivnewton
in index.php:
<jdoc:include type="modules" name="moduleRechts" style="" />
in modules.php:
function modChrome_warenkorb($module, &$params, &$attribs) { ?>
<h3>Title: <?php echo JText::_( $module->title ); ?></h3>
<?php echo $module->content; ?>
<?php
I don't see why it wouldn't work.
Do you see the h3 tags where the module title should be ? Maybe it's the translation which removes the title.
You could try without the JText::_() function call.
If you remove the display of the content of your chrome function, do you still see the content of the module ? If so, it could mean that it is a cache problem, or the wrong style selected in the dropdown (maybe two styles with similar names, or something ?)
- olivnewton
i dont even see the h3 tags, thats why i added for test <h3>Title: ... in my code.
so its not the translation or jtext::...
if i remove the module style in advanced or set it to default / inherited it still shows up the same...
it is not a cache problem. joomla caching is disabled and i cleared browser caching several times.
today i even work from homeoffice on a different pc...
it is also not 2 styles with similar names, as "warenkorb" is present only once...
i tried again to make chrome changes to other modules, different styles etc. it all works!!!
all except the hikashop cart module...
i just read my posts in this thread from the beginning, my very first question was if this could happen due to the fact that i am using the "mini cart" but as nobody answered specifically on this i assumed the answer would be "no". so again: could it be that "mini cart" is the reason?
- olivnewton
and:
in modules/mod_hikashop_cart/mod_hikashop_cart.php
line49
echo $html seems not to contain the title...
- olivnewton
any news here?
It's normal to not have the title in the $html of the cart module. It's no handled by HikaShop.
We just display the content inside the module, not the whole module and it's title.
That really seems to be a Joomla / template issue than a HikaShop one.
- olivnewton
as you can see in #160722 all i am doing is right.
nicolas wrote he cant see any mistake...
any way i could provide you with more information in order to debug this?
all other modules work (custom and not) the same way, all get the styling i define in modules.php ...
all except the hikashop cart (no matter if minicart or not)...
Is you title a simple title ? Or there is specific characters inside ?
- olivnewton
yes, it is a simple title without special characters...
i tried also other hika modules (for example "hika shop content module"... same problem, no title showing up at all, even if i select in "module manager" > "advanced" > "module style" : any style through all styles of my template... tried them all through, even those custom ones in joomla, even "inherited"...
with other joomla modules (for example "who's online"), title shows up when i select the appropriate style in "module style" out of my template...
i even changed the code in modules.php from
<h3><?php echo JText::_( $module->title ); ?></h3>
to
<h3><?php echo $module->title; ?></h3>
(removed JText::_)
still, it doesnt work. it looks like if hikashop modules totally ignore the setting in "module manager" > "advanced" > "module style" !!!
- olivnewton
FYI:
i installed hikashop 2.3.1 on a new site we are building, this one with blank template and no modules or overrides so far... if i make all configurations as i need, and enable the hikashop cart module, again it shows no TITLE!
also i just updated to 2.3.2, same error, no title displayed...
did you try to reproduce this?
