- Thank you received: 2
mini cart and module cart enabled at the same time
12 years 5 months ago - 12 years 5 months ago #158444
by nokki00
mini cart and module cart enabled at the same time was created by nokki00
-- url of the page with the problem -- : local
-- Joomla version -- : 3.3
-- PHP version -- : 5.3.24
I have a need to have the mini-cart and the module cart to be enabled at the same time. But there seems to be a javacript load or ajax conflict. The mini cart works fine but the regular module cart works doesn't update via the ajax. I would have to manually refresh the page to get the module cart to update. How can have these both enabled at the same time and both update with refreshing the page?
Also which ever one is loaded fist is usually the one that works right.
Thanks!
Thanks!
Last edit: 12 years 5 months ago by nokki00.
- Thank you received: 1778
12 years 5 months ago #158446
by Mohamed Thelji
Replied by Mohamed Thelji on topic mini cart and module cart enabled at the same time
Can you set the "Use AJAX when possible for add to cart buttons" option to NO through "Hikashop->System->Configuration->Main", and try it again ?
12 years 5 months ago - 12 years 5 months ago #158515
by nokki00
Replied by nokki00 on topic mini cart and module cart enabled at the same time
Ahhh that worked! ok I deal with the refresh for updating. Ideally I would like to use the Ajax feature for both modules. Is that possible?
12 years 5 months ago #158531
by Xavier
Replied by Xavier on topic mini cart and module cart enabled at the same time
This had not been thinking for this kind of use, but we have in our todo list to improve this part.
Adding JavaScript events to handle the add to cart on many cart, with a future possibility to have effect when adding to cart, etc.
12 years 5 months ago #158743
by nokki00
Thanks I hate to ask but will this be added to the next update?
12 years 5 months ago #158746
by Xavier
Hmm at this time I can't tell if it will be or not in the next release, sorry.
Time to create page: 0.087 seconds
