Delete products from cart
12 years 5 months ago #159952 by Boudewijn
-- Joomla version -- : x.x
-- PHP version -- : x.x.x
Perhaps it is a small bug then it easy to solve.
When I want to move products to the dustbin (in the back-end) it add products to the cart instead of deleting.
And I also get messages from customers that they cannot delete products from there cart.
Is this a known issue?
12 years 5 months ago #159955 by nicolas
Replied by nicolas on topic Delete products from cart
It is not a known issue.
Are you able to reproduce the problem on your website ? On our demo website ? Are you using the latest version of HikaShop ?
12 years 5 months ago - 12 years 5 months ago #160042 by Boudewijn
Replied by Boudewijn on topic Delete products from cart
Thanks for your reply.
I created basket id 158.
When I try to delete a product in the backend it copies another product in the basket.
What I use as an explorer is firefox
to edit
once a product is twice in the basket you cannot delete it in the front end. I click on the delete button, then the screen goes to login.
When I'm back in my cart. the product is simply not deleted. Looks like some sort of loop
Last edit: 12 years 5 months ago by Boudewijn.
12 years 5 months ago #160054 by Mohamed Thelji
That's maybe coming from a cache issue so can you disable the Joomla cache, and clear it ? You'll also have to disable it in the joomla config, and unpublish the cache plugin. Also can you clear your browser's cache and try it again ?
12 years 5 months ago #160194 by Boudewijn
Thanks,
I will try that. Hope that this works, otherwise you'll hear me.
12 years 5 months ago #160246 by Boudewijn
Hi Mohamed,
Sorry, that didn't solve the issue.
On both places (back-end and front-end) you can't delete a product from the basket.
In the back-end it just copies the product.
I think this is also linked to the issue.
perhaps you can see it for yourself
www.dodowear.nl
Orders are sometimes twice comfirmed in the reports in the control panel.
by the way I'm using the latest 2.3.1 version on the jm 2.5
12 years 5 months ago #160290 by Boudewijn
I think I got it.
After a re-install it works again.
12 years 5 months ago #160261 by nicolas
I was able to reproduce the problem with the product deletion on the cart page display. I've fixed it but it required modifications in 6 different files.
As it's not practical to give all that in a post, I can provide a full install zip of a pre version of next version of HikaShop, if you request it via our contact form (in that case, please give a link to this post and your HikaShop order number), or you can wait for next version of HikaShop for the fix (should be available before the end of the month).
6 years 1 month ago #324754 by Nanskio
Replied by Nanskio on topic Delete products from cart
Sorry to reopen older post. I have problem with hikashop cart. When I put product in the cart it can't be deleted either you are loged in or not. Is there any explanation why is that?
Thank you in Advance
This is the website www.tiaraflower.taorbita.com.mk
6 years 1 month ago - 6 years 1 month ago #324769 by Philip
Replied by Philip on topic Delete products from cart
There are a point you can check in Checkout Workflow, from Main HikaShop Configuration, Checkout tab => Checkout Workflow, in your Cart module check for the "Show delete icons in the cart" option.
But there are something quite strange about your Html, can you process some test with a default template like ProtoStar ?
The point of this test is to check that your current issue don't come from your template.
Awaiting news from you to progress on your subject.
Last edit: 6 years 1 month ago by Philip.
6 years 1 month ago #324782 by Nanskio
Thank you very much Philip. I have checked read only YES on the cart module. So when I check NO the button appears.
Than You again
