- Thank you received: 2
no products in cart "checkout"-btn showing
12 years 5 months ago #161994
by squareweb
no products in cart "checkout"-btn showing was created by squareweb
mywebsite.com/mypage
-- Joomla version -- : 3.3.1
-- PHP version -- : 5.4
-- Browser(s) name and version -- : chrome latest
1. add product to cart ==> checkout button in mini cart is showing (top of screen on the right)
2. delete product from cart ==> checkout button still showing (should be gone)
seems cart is not emptied fully when deleting products from orderlist?
see example: csm.siteflex.nl/index.php?option=com_hik...yout=show&Itemid=242
Tried clearing (joomla/browser)cache, no results
Any help is welcome.
Thanks in advance
Mark
Thanks in advance
Mark
12 years 5 months ago #162045
Replied by nicolas on topic no products in cart "checkout"-btn showing
Could you please try to turn on the "group options with product" option of the configuration and see if that helps ?
12 years 5 months ago #162121
by squareweb
Replied by squareweb on topic no products in cart "checkout"-btn showing
Nicolas thanks for quick response.
I've done what you asked and:
1. cleared browser cache
2. cleared Joomla-cache
Still the show-cart-button in mini cart is visible.
Is there a way to force cart-clearance in some way or another?
Thanks in advance.
Mark
Thanks in advance.
Mark
- Thank you received: 1778
12 years 5 months ago #162122
by Mohamed Thelji
Replied by Mohamed Thelji on topic no products in cart "checkout"-btn showing
I just tested it and it's working fine.
That's maybe coming from a cache issue so can you disable the Joomla cache, and clear it ? You'll also have to disable it in the joomla config, and unpublish the cache plugin. Also can you clear your browser's cache and try it again ?
The following user(s) said Thank You: squareweb
12 years 5 months ago #162231
by squareweb
Mohamed,
Thanks for pointing out. Indeed it was a cache-thing.
I've closed all my browser-windows and quoted the browser from OSX.
After that it worked as expected.
Thanks again.
Mark
Thanks again.
Mark
