Problem with checkout and its redirect url
12 years 2 months ago - 12 years 2 months ago #169761
by Awhowas
Problem with checkout and its redirect url was created by Awhowas
-- Joomla version -- : 3.3.3
-- PHP version -- : 5.4.24
i've got a problem in a checkout. I need to redirect my visitors on my homepage, but i have a problem. My website is a multilanguage e when i redirect the people on index.php, when checkout is empty, redirect is to index but in another language and not in the same where the shop is. But if I write only a / in the redirect of checkout, all the page will be with the same url: websitefolder/index.php/, but the index is correct, but the url don't change. How can i do to fix ?
:dry:
:dry:
Last edit: 12 years 2 months ago by Jerome.
12 years 2 months ago #169806
by Xavier
Replied by Xavier on topic Problem with checkout and its redirect url
Which multilangue system are you using ?
The redirect should be in the correct language, the language data is stored in session, so redirecting should not cause any issue.
12 years 2 months ago #169820
by Awhowas
Replied by Awhowas on topic Problem with checkout and its redirect url
I'm using joomla in general without external component and hikashop is the free version. You aren't able to give me a resolution for this problem ? The problem is that each url, is composed by index/tag-language/name of store's page. If i write the same alias and i redirect to it, that doesn't work the same.
12 years 2 months ago #169935
Replied by nicolas on topic Problem with checkout and its redirect url
Just enter the domain name of your website. The system will redirect to it and normally Joomla will add back automatically the current language tag in the URL.
