Problem with product
12 years 2 months ago #170055 by hikalikethat
-- Joomla version -- : 3.3.0
-- PHP version -- : 5.5.11
-- Browser(s) name and version -- : IE 11
I have a software product ($100) that can have optional software maintenance ($20). When i go to the product page in hikashop, it displays the product option (as listed under Options), but it's a separate line item in the cart (one line shows $100 and the other line shows the maintenance option in another line for $20).
How do I configure hikashop's prdoucts so the option shows up in one line?
12 years 2 months ago #170057 by Jerome
Replied by Jerome on topic Problem with product
www.hikashop.com/support/support/documen...onfig.html#main_cart
Group options with products : When that option is activated, the options will be displayed together with the main product in the cart while when the option is deactivated, each option will be considered as a separate product in the cart.
The following user(s) said Thank You: hikalikethat
12 years 2 months ago #170214 by hikalikethat
Replied by hikalikethat on topic Problem with product
That worked. Except how do I not have it listed as a product when I go to the Hikashop cart?
12 years 2 months ago #170242 by nicolas
Replied by nicolas on topic Problem with product
If you activate the "group options with product" option, the options won't be listed as products on the HikaShop cart. So you should already be all good if you activated it.
