Accept terms and conditions problem
12 years 2 months ago #170152 by innoads
-- url of the page with the problem -- : private
-- Joomla version -- : 3.3.1
-- PHP version -- : 5.4.4
when I do following steps
1. not logged in -> add an item to cart -> go to cart -> check terms -> register -> pay
2. logged in -> add am item to cart -> go to cart -> check terms ->
a) click on x to remove an item
or
b) click on update the quantity of an item
or
c) click on continue button
an Error message shows that I must accept the terms (although it is checked already) and I can not proceed.
What could cause this issue?
Thanks and regards,
Andreas
12 years 2 months ago #170165 by Mohamed Thelji
Hello Andreas,
Can you show me some screenshots of how did you configured the page "Hikashop->System->Configuration->Checkout" ?
Also, if you are using a SEF module / SEF options, can you disable it and try it again so that we can know if it's coming from it ?
12 years 2 months ago - 12 years 2 months ago #170265 by innoads
Hello Mohamed,
please find screenshots for "Hikashop->System->Configuration->Checkout" attached.
Do you mean Hikashop SEF options only or also Joomla standard SEF? I have set Hikashop SEF as in the attached screenshot and Joomla is set to have Search Engine Friendly URLs and to Use URL rewriting. I tried to disable both together and individually. All three times normal navigation in hikashop categroies was not possible anymore.
Last edit: 12 years 2 months ago by innoads.
12 years 2 months ago #170286 by Jerome
Without a link to your website, it will be difficult to see the problem directly and tell you more about the problem.
I don't think it will come from the SEF ; but without having a look, I can't provide any useful idea.
12 years 2 months ago #170354 by innoads
Hi Jerome,
I am going to send you the access via private message.
12 years 2 months ago #170758 by innoads
Hi Jerome,
have you received my private message and have you had a chance to look at it?
Thanks,
Andreas
12 years 2 months ago #170766 by nicolas
We looked at your website but couldn't reproduce the problem.
It worked fine and we were able to continue the process each time.
Maybe it comes from a user session glitch on your browser. Could you try with another browser ?
The following user(s) said Thank You: innoads
12 years 2 months ago #171276 by innoads
thanks for looking at my site.
On a different browser it works for me, too.
