- Thank you received: 3
Incomprehensible problem with checkout.
- Rabbiteggs
12 years 2 months ago - 12 years 2 months ago #173246
by Rabbiteggs
Incomprehensible problem with checkout. was created by Rabbiteggs
tritatusha.ru
-- Joomla version -- : 3.3.3
Hello everyone,
I have a problem with my checkout page. When i'm put something in my cart and then go to checkout page,there I'm doesn't see my order, only any other orders(not my), and on the home page he shows that there is no items in your cart.
Thnx to all who will try to help me.
Hello everyone,
Last edit: 12 years 2 months ago by Rabbiteggs.
- Thank you received: 1778
12 years 2 months ago #173302
by Mohamed Thelji
Replied by Mohamed Thelji on topic Incomprehensible problem with checkout.
It's maybe coming from a cache issue so can you disable the Joomla cache, and clear it ? You'll also have to disable it in the joomla config, and unpublish the cache plugin. Also can you clear your browser's cache and try it again ?
- Rabbiteggs
12 years 2 months ago - 12 years 2 months ago #173360
by Rabbiteggs
Replied by Rabbiteggs on topic Incomprehensible problem with checkout.
I try and it work, but it work earlier with joomla cache plugin too.
Google Pagespeed reccommends to use browser caching to increase page loading speed.
12 years 2 months ago - 12 years 2 months ago #173408
by Jerome
Replied by Jerome on topic Incomprehensible problem with checkout.
Sure they do.
But an e-commerce system is not compatible with the cache.
You had the impression that the cache worked but the cache was building itself during your tests.
Sorry, the google recommendations are not the right one for everybody.
Sure they do.
Last edit: 12 years 2 months ago by Jerome.
