Problems with invoices
12 years 2 weeks ago - 12 years 1 week ago #179116 by Bibok
Problems with invoices was created by Bibok
-- Joomla version -- : 3.3.1
-- PHP version -- : 5.4.27
Hello everyone. This is the problem:
We set the shop to pay by credit card and initially the bank receives the payment notification. However, neither the user nor the administrator receive any mail notification or invoice. We tested our contact section on joomla and apparently, is working and we receive the contact mail, so we think the joomla mail configuration is ok. (We are using php mail. )
We've taken a look at the orders. Both the invoice as the shipping invoice is created and stored on the server, but no mail is sent.
Any idea what could be happening?
Last edit: 12 years 1 week ago by Bibok.
12 years 1 week ago #179128 by Jerome
Or plugin or A PHP error could explain the trouble.
Please check your PHP error log.
12 years 1 week ago - 12 years 1 week ago #179311 by Bibok
Hello again.
We checked the website and finally we have seen that the problem was in the mail accounts. Now seems everything is in order, but we have doubts about the invoices:
• What can I do to make the user receive the invoice directly on his mail? (Now he only receives the order confirmation and creation mails)
• Is there a way for the admin to see all invoices at once?
• When the user clicks in his order, he go to the index screen an receive this error (Up To the right)
• What can I do to change the invoice number? I don't want random numbers like U18, T16, etc. I would like the numbers are consecutive.
12 years 1 week ago #179432 by Xavier
1. To have the invoice as PDF attached to the email, you will need:
hikashop.com/component/hikashop/product/cid-18.html
2. The admin can see the listing of the orders in backend, but not all the invoices at once.
3. Do you have added custom order fields ? Please try to disable the added ones to see if it's working that way.
4. You can edit the value of the option "Invoice Number format" in Configuration > Main > Order.
12 years 1 week ago #179452 by Bibok
1. Ok. I'll check this. Thanks.
2. Ok. If the plugin works I'll send the same invoice to the shopper and the admin, right?
3. I don't have any custom order field, so I think is a problem with the template... Can we desable the link and leave without it? We can add custom text on the mail to the customers? To add a simple "Go to the panel for more information" and avoid the problem.
4. Ok. Can you provide us some examples of the possibilities to edit this? For example, If I want only consecutive numbers without a letter?
Thanks for the information!
12 years 1 week ago #179488 by Xavier
2. No the email with the pdf attached is only sent to the customer by default, but you can add some code to the email to add your address as bcc. You should find other topics about that on our forum.
3. As you said it seems to be more a Joomla / template issue than an HikaShop one. The link can be removed by editing the email via the menu System > Emails and instead of using custom field, you can directly add your text string in the email content.
4. You just have to use
id
12 years 1 week ago - 12 years 1 week ago #179590 by Bibok
2. Ok, We'll check that and we''ll see if we can make it works. Can I reset the number invoices and order? How?
3. Ok, I've tried to edit the email, but I broke it, so I supose, once again ,I don't know what line I need to edit to remove the link. For example, on the notification mail, I have three codes:
HTML
** Original content of the order notification html of HikaShop 2.3.4 **
TEXT:
** Original content of the order notification text of HikaShop 2.3.4 **
PRELOADED VERSION
** Original content of the order notification preload of HikaShop 2.3.4 **
I tried to edit and delete de $url, but then the whole message dissapears... So I think I'm not editing the correct line, right?
Last edit: 12 years 1 week ago by Jerome. Reason: Removing email content which is the same than the original HikaShop files
12 years 1 week ago #179602 by Xavier
In the preload part, replace:
'ORDER_CHANGED' => JText::sprintf('ORDER_STATUS_CHANGED_TO', $url, $data->mail_status),
By:
'ORDER_CHANGED' => JText::sprintf('ORDER_STATUS_CHANGED_TO', $data->order->order_number, $data->mail_status),
12 years 1 week ago - 12 years 1 week ago #179933 by Bibok
Thanks a lot! The link is now removed! Now we can send emails without think on the template.
We have a few of questions:
1. If we want to delete all the invoices we created for test purpose and reset the order and invoices ID? Do we need to modify some files or...?
2. When a product is out of stock, how can i know it? I mean, is there any option that allows to send me an email when a product is out of stock?
Thanks!
11 years 11 months ago - 11 years 11 months ago #182414 by Mohamed Thelji
1. You have to do go to your phpMyAdmin interface and on the #__hikashop_order and #__hikashop_order_product tables use the "empty table" functionality. This way it will erase the data and reset the ids.
2. Sure, you can enable the "'Out of stock notification" email via "Hikashop->System->Emails" which will notify you when a product is out of stock.
Last edit: 11 years 11 months ago by Mohamed Thelji.
