Popup in Cart does not work
- CMS-Buttler
12 years 3 days ago #181182
by CMS-Buttler
Popup in Cart does not work was created by CMS-Buttler
-- HikaShop version -- : HikaShop Business 2.3.4
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.4.30
-- Browser(s) name and version -- : Firefox 33
Hello support Team,
the pop up for terms of use is not working.
awesomescreenshot.com/0ab3wutb05
thx
andreas
Hello support Team,
thx
andreas
12 years 2 days ago #181269
by Xavier
Replied by Xavier on topic Popup in Cart does not work
Are you sure that you have selected a valid article ?
On your page, there is no Javascript errors, but the code try to get an invalid article, because it has letters instead of the article id.
Please try to reselect the article in the HikaShop settings.
- CMS-Buttler
12 years 2 days ago #181360
by CMS-Buttler
Replied by CMS-Buttler on topic Popup in Cart does not work
i changed the article
but it wont open a popup
thx
thx
12 years 18 hours ago #181579
by Xavier
Do you had edited the view "checkout / terms" ? Is that view up to date ?
I don't see any errors, and now the html code is correct.
Potentially a missing javascript library due to your template.
Please try to enable the Joomla debug mode and try again, if it's working with the debug mode so some javascript is missing in your template.
- CMS-Buttler
12 years 17 hours ago #181586
by CMS-Buttler
okay in debug mode it works.
how can i find out which java lib is missing?
thx
thx
- CMS-Buttler
12 years 16 hours ago #181600
by CMS-Buttler
12 years 2 hours ago #181665
Replied by nicolas on topic Popup in Cart does not work
Try to change the "popup mode" option of the Display tab of the HikaShop configuration to one of the different values and see if one of them help circumvent the problem.
