Problem with value of Characteristics from Product
11 years 11 months ago #181831 by 42bit
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.3.29
-- Browser(s) name and version -- : Firefox 33.1
I've this issue.
If I selected a size M in product page, and them I click on "ADD TO CARD", the system writes a wrong size in checkout page (XXL), as you can see in the screenshot that I've attached.
Can you help me.
Thank you
Antonio
11 years 11 months ago #181855 by Mohamed Thelji
Hello Antonio,
Your issue is probably coming from some file customization of the "product" view via "Hikashop->Display->Views", Can you check it and test it without your customization ?
11 years 11 months ago #182084 by 42bit
HI I've tried to use the original "product" view, I have a backup file, but problem is still there.
How can I do?
Antonio
11 years 11 months ago #182143 by Mohamed Thelji
Can you directly go the the "Hikashop->Display->Views" page and directly check that you don't have any modification through the files of the "product" view of your front-end template and then remove it to test it without any customization ?
The following user(s) said Thank You: 42bit
11 years 11 months ago #182192 by 42bit
It's right!
I've deleted all custom display views in staging site and now it works well.
Thank you
Antonio
