Cart module and custom fields
11 years 9 months ago - 11 years 9 months ago #189478 by saturnsky
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.3.28
I found a partial answer to this problem but I wanted to know if there was a simpler solution. I do not wish to remove the custom fields from the cart module on checkout but I do want to remove from the cart module I have created and placed on the sidebar. This code:
hikashop_cart_product_custom_item_fields{display:none; }
removes it completely from the checkout cart module. No good.
This code:
hikashop_cart_module .hikashop_cart_item_(where this is the custom field name) {display: none;}
removes one custom field but if you have many fields this can get extremely time consuming as you have to enter them one by one.
Is there a code that will work more efficiently? I have tried several combinations using .hikashop_cart_product_custom_item_fields
but cannot get anything to work.
Thanks for any info.
Last edit: 11 years 9 months ago by saturnsky.
11 years 9 months ago #189499 by Xavier
I think that you have to use something like:
#hikashop_cart_module .hikashop_cart_product_custom_item_fields{display:none; }
#hikashop_cart_module allow to restrict the property only for the cart module.
