CheckOut Workflow Problem
11 years 8 months ago #195230 by VagiaG
-- url of the page with the problem -- : pharmacy.websters.gr
-- Joomla version -- : 3.4.0
-- PHP version -- : 5.6.3
I'm currently working on a test site and we are a few steps away from going online... For the checkout process I'm using a 6 step checkout workflow
1. Login - Address
2. Shipping
3. Payment
4. Cart - Coupon
5. Terms & Conditions
6. Finish
My problem is that if a client use the top bar for proceeding to his check out instead of the next button on the right bottom, when it comes to step 6 he gets a "thank you for your order" message but no order is created and the cart won't empties. Especially, if bank deposit is selected as a payment method, the Bank Account doesn't show, but the customer stays with the impression that his order was created. Currently I have a message that asks from customers to use the right bottom button instead of the bar steps, but this isn't a good solution as it indicates a malfunction.
Any help would be highly appreciated!
Thanks in advance!
11 years 8 months ago #195271 by Jerome
Replied by Jerome on topic CheckOut Workflow Problem
You can create an override the view "checkout | step" and replace
if($k == $this->step || empty($link)) { echo JText::_('HIKASHOP_CHECKOUT_'.strtoupper($step_name)); } else { ?> <a href="<?php echo hikashop_completeLink('checkout&task=step&step='.$k.$url_itemid);?>"> <?php echo JText::_('HIKASHOP_CHECKOUT_'.strtoupper($step_name));?> </a> <?php
By
if($k == $this->step || $k > $this->step || empty($link)) { echo JText::_('HIKASHOP_CHECKOUT_'.strtoupper($step_name)); } else { ?> <a href="<?php echo hikashop_completeLink('checkout&task=step&step='.$k.$url_itemid);?>"> <?php echo JText::_('HIKASHOP_CHECKOUT_'.strtoupper($step_name));?> </a> <?php
So the next step won't have any link where the user will be able to click on.
The following user(s) said Thank You: VagiaG
11 years 8 months ago - 11 years 8 months ago #195425 by VagiaG
Replied by VagiaG on topic CheckOut Workflow Problem
Thanks a lot for your reply! I was hoping for a fix that would make the navbar work right, but that works too!!!
Last edit: 11 years 8 months ago by VagiaG.
