- Thank you received: 1
problem with save button using 'dropdown list'
11 years 6 months ago - 11 years 6 months ago #201887
by reders
problem with save button using 'dropdown list' was created by reders
www.totalpipes.co.uk/
-- Joomla version -- : 3.4.1
-- PHP version -- : 5.4.40
-- Browser(s) name and version -- : All browsers
We built an ecommerce website using Hikashop, and are using the 'Dropdown List' for the address selector.
There is a serous usability issue that we need to fix.
In checkout, when someone unchecks 'Use the same address as for billing', the address form appears - which is good.
The problem is that the 'save' button appears at the top of the form!
So we've done some user testing and, when a user fills in their details, they naturally click 'Next' instead of the 'save' button.
I need to move the save button underneath the form, but this appears to be impossible because the form and save button seem to be loaded dynamically.
How do I go about moving the save button underneath the form?
Many thanks
Many thanks
Last edit: 11 years 6 months ago by reders.
11 years 6 months ago #201905
by Jerome
Replied by Jerome on topic problem with save button using 'dropdown list'
You can override the view "address | show" and move that part of
You can replace it by
And then add the content
below in the view, like just before that code
} else {
?> <div class="hika_edit">
<a href="<?php echo hikashop_completeLink($save_url, true);?>" onclick="return window.hikashop.form(this,'<?php echo $this->fieldset_id; ?>');"><img src="<?php echo HIKASHOP_IMAGES; ?>ok.png" alt=""/><span><?php echo JText::_('HIKA_SAVE'); ?></span></a>
<a href="<?php echo hikashop_completeLink($show_url, true);?>" onclick="return window.hikashop.get(this,'<?php echo $this->fieldset_id; ?>');"><img src="<?php echo HIKASHOP_IMAGES; ?>cancel.png" alt=""/><span><?php echo JText::_('HIKA_CANCEL'); ?></span></a>
</div>
<?php
if(!isset($this->edit) || $this->edit !== true ) {
</div>
<?php
if(isset($this->edit) && $this->edit === true) {
echo '<input type="hidden" name="data['.$name.'][address_id]" value="'.$this->address_id.'"/>';
echo JHTML::_( 'form.token' );
