Does not work switcher "Identification"
11 years 5 months ago #206441 by IGrock
-- Joomla version -- : 3.4.1
-- PHP version -- : 5.6.6
Hello HikaTeam,
I have setup under Login & Registration:
But on the frontpage when you switch Identification is always the Login form:
How to fix it?
11 years 5 months ago #206452 by nicolas
This depends on the CSS of the bootstrap library of your template as we don't have that issue on our end with the default template of Joomla.
Could you provide a link to the shop so that we could check the CSS there ?
The following user(s) said Thank You: IGrock
11 years 5 months ago #206538 by nicolas
I've got your link. It seems that the view displaying that element has been modified by your template to add extra classes to handle the coloring. If that's the case, you can rename the file templates/YOUR_TEMPLATE/html/com_hikashop/checkout/login.php via FTP in order to deactivate the override.
Otherwise, modifying the CSS of the template would also be a solution but you should seek advice with your template provider.
Also note that there are several javascript errors on the pages:
take.ms/wMXxy
These also come from the template javascript files and prevent the switcher to actually work on your website (regardless of what you select in it, you always see the login form). You should also seek advice wih your template provider for help fixing these javascript errors.
11 years 5 months ago #206553 by IGrock
It is, template.js overrode the CSS, I removed it and it worked. Thank you!
