Checkout menu position and href in cart module
11 years 4 months ago - 11 years 4 months ago #208766 by Gnsbud
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.5.12
-- Browser(s) name and version -- : Firefox 37.0.2
I've Hikashop Checkout Joomla menu position (HikaShop » checkout), the alias of this menu position is "checkout" (it's top level menu item).
I've in Hikashop backend main config -> SEF url options -> Checkout SEF name: checkout
Now, in cart module (default Hikashop cart module) I have checkout button href which points to: example.com/checkout/checkout, but when I do main config -> SEF url options -> Checkout SEF name: [empty], then checkout url in cart module looks like this: example.com/checkout (as wanted).
If I disable Checkout menu position and in main config -> SEF url options -> Checkout SEF name: checkout, then in cart module href looks like this: example.com/component/hikashop/checkout/Itemid=
Is this correct behaviour? Shouldn't this be (if menu position assigned): example.com/checkout, no matter if Checkout SEF name is filled or not?
What's more, something bad happens with SEF while I'm on another Hikashop menu position (for example category): sometimes in cart module Checkout href looks like this: example.com/some-category-alias/category/checkout (depends where am I right now), for example if I'm on manufacturer assigned menu I got: example.com/some-manufacturer-alias/checkout
As there're are tons of options, please, ask me about some settings and I'll post print screens or info.
Best regards,
Chris
Last edit: 11 years 4 months ago by Gnsbud.
11 years 4 months ago #208778 by nicolas
That's the correct behavior.
You'll want to select your checkout menu item in the "force menu on checkout" setting of the Checkout tab of the HikaShop configuration in order to always get the same URL on the checkout.
The following user(s) said Thank You: Gnsbud
