- Thank you received: 1
Issue with VAT not charged for particular country
11 years 3 months ago #211031
by miwhel
Issue with VAT not charged for particular country was created by miwhel
-- Joomla version -- : 3.4.3
We have a strange situation where VAT has not been charged on an order for a particular country.
We have two tax categories set up in Hikashop:
Default Tax Category with restriction as Zone: United Kingdom.
Overseas with restriction as Zone: Overseas
Both of these tax categories are set to charge VAT at the same rate
We have had a customer buy some items from the store with an Overseas address. The country of the address used (Sweden) is a sub-zone of the Overseas zone so they should have been charged VAT at the Overseas tax category rate, but they were not charged VAT at all.
I have tested this as a test customer for which I have added 3 addresses. One for the UK, one for Sweden and one for Australia.
If I select the UK or Australia address, Hikashop shows VAT is added at the checkout, but if I select Sweden as the address, no VAT is added at the checkout.
So the issue of VAT not being charged is with the address, but as Sweden is included as a sub-zone of the Overseas zone which is the zone used for the Overseas tax category, I don't understand why.
Please can you advise asap as we want to avoid this situation arising again.
Thanks in advance.
Thanks in advance.
11 years 3 months ago #211032
Replied by nicolas on topic Issue with VAT not charged for particular country
When you create a product, you select the tax category of the product.
So a product has only one tax category.
If you created two tax rules linked to two different tax categories, only the tax rule linked to the tax category of the product will be relevant for the calculation of the tax for that product.
So what you actually want is to have only one tax category and link both of you tax rules to that tax category.
If you read our documentation on tax setup, that's what we recommend you do:
www.hikashop.com/support/support/documen...axation-listing.html
The following user(s) said Thank You: miwhel
11 years 3 months ago #211050
by miwhel
Replied by miwhel on topic Issue with VAT not charged for particular country
Thanks Nicolas for your guidance on this.
I have now unpublished the overseas tax category so the only one live is "Default tax category", but it makes no difference to the checkout result. If the address in the UK or Australia is selected for the customer at checkout then VAT is included, but if the address in Sweden is selected then no VAT is included. So it appears to be associated with the Address country and not the products.
What am I misunderstanding or is there an issue?
Thanks again...
Thanks again...
11 years 3 months ago - 11 years 3 months ago #211051
by miwhel
An update to my response above. I have now seen in the Default tax category that was set with a Restriction value of "United Kingdom". Removing that has meant that the address in Sweden is now showing as including VAT - which is good.
But... that doesn't explain to me why the Address in Australia was already showing as including VAT before I removed the restriction.
What would have caused that?
Additionally, although I have now unpublished the Overseas tax category it is still showing in the dropdown selection options for existing products AND if I create a new product, the pre-selected Product tax category dropdown has Overseas as the selection. What is going on with that?
Last edit: 11 years 3 months ago by miwhel.
11 years 3 months ago #211070
Just disabling the overseas tax category won't solve anything.
As I said in my previous message, you need to edit your tax rules and select the "default tax category" as "tax category" for all of them.
Tax categories don't have any restrictions. You must be talking about tax rules using the "default tax category" as tax category.
As you didn't provide screenshots of the settings of your tax rules, it's hard to tell you why it does something or not.
Regarding the selection of the tax category, you should delete it if you don't want it anymore (and you don't since you don't want to use it). Then you won't see it in the selection dropdown.
11 years 3 months ago #211135
by miwhel
Thank you Nicolas. I think the confusion has come because the "overseas" option was set in both Configuration > System > Taxes showing in the Product tax category column and under the Manage tax categories button in the same area.
I had assumed that they were different but testing this, if setting a new tax category under the Manage tax categories button, that doesn't show in the main Tax rules screen in the Product tax category column.
I am still not sure I understand the difference in these, but deleting the extra rule under the Manage tax categories button also removes it as an option when creating a new product.
Thanks for your help.
11 years 3 months ago #211138
by Jerome
Replied by Jerome on topic Issue with VAT not charged for particular country
Having two different tax category is more than useful when you have products with different kind of products with different taxes rates.
Like for example the food or the alcohol which have special tax rates in a lot of countries.
