Cart Module Not Correctly Translated
11 years 3 months ago #212446 by Nello
-- Joomla version -- : 3.4.3
Use the website in english and add a product to the cart. You will note that the cart module on top right corner of the page still be in italian language and clicking on the button "vai alla cassa" it will redirect to the italian page of checkout.
How can I solve?
11 years 3 months ago #212476 by nicolas
This has nothing to do with HikaShop as the module title is handled by Joomla and displayed by your template.
The module title can be configured in the Joomla module manager when you edit the module.
Joomla handles the translation of modules by creating several instances of the module and restricting each one to a different language. So you would have to do that.
Or you can also use Falang to translate your modules title.
11 years 3 months ago #212497 by Nello
The problem is not the translation but the fact that the button, if you are browsing website in english, still rest in italian language and it will redirect you to the italian check out page.
What is the php file in hikashop that control the cart?
11 years 3 months ago #212510 by nicolas
Then it means that you must have selected a menu item linked to the italian language in the "force a menu on checkout" setting of the HikaShop configuration. Don't link it to the Italian language.
And if you want to translate it, use Falang instead of the Joomla language linking mechanism.
11 years 3 months ago #212583 by Nello
No, that's not the problem. Unfortunately I think the problem is an incorrect ajax or javascript loading of cart module. Maybe due of an error in the template script. That because if i load a cart module in another position out of the ajax loading all works fine :(
11 years 3 months ago #212613 by nicolas
In that case we can't help. You'll have to see that with the developer of your template.
The following user(s) said Thank You: Nello
