- Thank you received: 1
Checkout buttons problems
10 years 11 months ago #223289
by wichai
Checkout buttons problems was created by wichai
www.aromahub.com/th/our-products/checkout
-- Joomla version -- : 3.4.5
-- PHP version -- : 5.4.45
-- Browser(s) name and version -- : Chrome 46.0.2490.86 m
I have problem,please help. After filling out the address on the checkout page, when I click on the "'next" button,it bring me to the home page of the website. When I click on the continue shopping, it say "This webpage is not available". It had no problem in the past, just happened. I am not sure that I might did something wrong on the checkout process or something else such as language setting, etc. Please give me suggestion
Thank you very much
Thank you very much
10 years 11 months ago - 10 years 11 months ago #223304
by Philip
Replied by Philip on topic Checkout buttons problems
In order to check all your configuration can you mail us via our contact form some references to access your administrator back-end.
Don't forget to add this subject url on your email subject.
Last edit: 10 years 11 months ago by Philip.
10 years 11 months ago #223423
by wichai
Replied by wichai on topic Checkout buttons problems
Already sent
Thanks for your help
10 years 11 months ago - 10 years 11 months ago #223459
by Philip
First I change in :
- Components -> HikaShop -> Configuration
- Click on Checkout tab
- I enter a new url, on your Continue shopping button's URL, before it's was a localhost url.
And so, the "continue shopping" button work now fine.
Second, I processed to a lot of test, and everything in your configuration look fine, so I'm bit surprised by this issue.
So I suggest to update your HikaShop Business version via your customer account (a new release have been done in december and correct some bug)
If trouble remains, we will process other test but for this I will require your ftp access, like previous email it with our Contact Form and don't forget to add this subject url in email subject.
First I change in :
10 years 11 months ago #223611
by wichai
I have tried to re-install Hikashop latest version again. But the problem is still persist. Another thing, I also found something strange in one of the product page(
Clove Leaf essential Oil page
)The product image is not clove leaf image as it used to be. It was changed to Cinnamon Leaf Oil image. No matter how many times I tried to change the image in the back-end to be Clove Leaf Oil image, it is not changed according to what I have done.
However, I will send you FTP access. Please help me to fix the issue
Thanks again for your help
10 years 11 months ago - 10 years 11 months ago #223712
by Philip
For your product image issue:
- The trouble come from your variants 30 มล. configuration you don't add the good picture
Second point on your next issue, I check your configuration and make some tests and I see only one thing you have one of your plugins that override your next button url...
You have only one solution to find it, unpublished one by one your plugin and each time make some test and see when it works.
When you get it, contact the plugin developer.
I'm sorry I can tell you more.
10 years 11 months ago #223752
by wichai
Dear Philip
Thanks for the suggestion, I will test as per advice.Hope I get some luck. Will let you know
Thanks again
Thanks again
10 years 11 months ago #223845
by wichai
Dear Philip
I have tested with each plugin turn off,but no luck. The proceed button on the checkout page still does not work. I am not a programmer.Therefore, it is quite difficult for me to source it out. Do you have any other suggestion which I should take a look further.? I will be very appreciated for your further suggestion.
Thank you very much.
10 years 11 months ago - 10 years 11 months ago #223847
by Philip
I have maybe one other idea: desactivate your Joomla! SEF option
Follow this way:
- System -> Global Configuration
- find : Search Engine Friendly URLs and switch it off
=> Make a test.
Note: I can do it myself because the references you gave me don't work anymore...
If your trouble always remains, I will require to access to your back end configuration.
Follow this way:
=> Make a test.
10 years 11 months ago #223950
by wichai
I switch off the SEF URLs, still no luck. Anything else which I should do? :S
You can use the same reference information to access my back-end website now.
Thank you verymuch
Thank you verymuch
10 years 11 months ago #224086
by wichai
Dear Mr. Philip
Any more advice for me,please
10 years 11 months ago #224108
by wichai
Dear Philip
Finally, I found my problem. It has conflict with the "Shape5 Quick contact". When I disable it ,the "proceed" button works as normal.
Thank again for your help.Appreciate.
