[Solved] Adding Ajax login to checkout work flow
10 years 8 months ago - 10 years 8 months ago #232177 by Seans
-- Joomla version -- : 3.4.8
www.hikashop.com/forum/checkout/876717-u...check-out-login.html
I read this article
I was wondering do you have to use PHP under Display>Views to add ajax login to checkout workflow after you disable hikashop login
Last edit: 10 years 8 months ago by Seans.
10 years 8 months ago #232178 by Jerome
Yes.
10 years 8 months ago - 10 years 8 months ago #232310 by Seans
Cool. PHP programming is past my skill set. Is there any copy and paste PHP programming i can add to display>views? Or do i have to write the PHP code self? Is there any plugin available for this purpose? Do you suggest any other login plugin that works with HIKA Checkout?
And lastly i want my AJAX login to Synchronize with Hikashop Login and i do not fully understand joomlas users system in relation to hikashop users and AJAX users.
Best Regards and RTS (respect tech support)
10 years 8 months ago #232314 by nicolas
I don't know of such plugin. And the code to write there is not simple and will require quite some time to write, even for a developer.
If it's really needed and you don't have the skills for that, I would recommend to contact our partners:
www.hikashop.com/home/our-partners.html
10 years 8 months ago - 10 years 8 months ago #232398 by Seans
This is not Mandatory i just thought it would be something to look into.
Im really lost on how the hikashop users and Ajax users work with the joomlas users system. Would having Ajax login along with the hikashop login create a conflict. So would creating an account through Ajax login give you the same credentials to login with Hikashop login? Can the two work harmoniously together? Or would that take me back to trying to add ajax login to the checkout timeline while disabling hikashop login. I was confused about how they work together so my work around attempt was adding ajax to checkout timeline. I know that probably isn't an option for me right now. Should i get rid of ajax login and only use hikashop login. Whats the easiest path? and whats the best path for performance?
RTS
10 years 8 months ago #232399 by nicolas
I suppose that Ajax login creates normal Joomla users. And HikaShop also creates normal Joomla users.
So both systems should work fine on the same website without requiring any code change. It's only fi you want to integrate the ajax login inside the HikaShop checkout instead of the normal login system of HikaShop that it would require code modifications.
The following user(s) said Thank You: Seans
