Help!! No forward to Payment provider anymore (Paypal and Ideal)
- Cybermissy
10 years 1 month ago - 10 years 1 month ago #252029
by Cybermissy
-- Joomla version -- : 3.6.2.
-- PHP version -- : 5.6.18
Hi! Please help :blink:
In the checkout proces I select Ideal or Paypal and the next page is the succes page. The payment process is skipped. Why and how to change this?
Also the cart is not empthy after succespage.
Thank you
Thank you
Last edit: 10 years 1 month ago by Cybermissy.
- Thank you received: 1778
10 years 1 month ago #252033
by Mohamed Thelji
Replied by Mohamed Thelji on topic Help!! No forward to Payment provider anymore (Paypal and Ideal)
Firstly, can you show me some screenshots of how you configured :
-Your checkout workflow via "Hikashop->System->Configuration->Checkout" by setting the "Advanced checkout workflow edition" option to NO
- Both of your payment methods
Thank you.
Thank you.
- Cybermissy
10 years 1 month ago #252102
by Cybermissy
Replied by Cybermissy on topic Help!! No forward to Payment provider anymore (Paypal and Ideal)
Hello Mohamed,
Hereby the screenshots.
Hope you have the solution.
Thank you!
Thank you!
10 years 1 month ago #252104
Replied by nicolas on topic Help!! No forward to Payment provider anymore (Paypal and Ideal)
I don't see why it would do that.
Could you provide a link to the shop and provide directions to reproduce the issue so that we could look at the problem ?
You can use our contact form if you don't want to display the information publicly:
- Cybermissy
10 years 1 month ago - 10 years 1 month ago #252183
by Cybermissy
I have sent you the details in the contactform.
Maybe it is helpful to know I have upgraded in two steps. From free to essential to businessedition.
It has worked before, cause I tested it some time ago. But I don't know what caused this change.
10 years 1 month ago #252271
You've modified the file "end" of the view "checkout" via the menu Display>Views:
take.ms/0xauQ
As you can see, you've replaced the code:
there, which displays the redirection form of the payment plugins by:
which displays your thank you message.
So it does exactly what you made it do.
Remove that customization and you'll see that it will work properly.
take.ms/0xauQ
echo $this->html;
echo JText::_('BEDANKT_VOOR_DE_BESTELLING');
- Cybermissy
10 years 1 month ago #252276
by Cybermissy
Wow how stupid! Thank you for your help!! I tested it only with offline payment methods so I haven't noticed this before.
- Cybermissy
10 years 1 month ago #252282
by Cybermissy
So where do I edit this succes-page?
I want to add some more text.
10 years 1 month ago - 10 years 1 month ago #252339
by Philip
Replied by Philip on topic Help!! No forward to Payment provider anymore (Paypal and Ideal)
You can edit or add your "Thank you page" in each of your payment plugins file.
Open and edit, the YOURPAYMENTPLUGIN_end.php, you will see some html that manage the little message you see at the end of the process.
Feel free to add some html to customize the message.
Hope this will fit your needs.
Last edit: 10 years 1 month ago by Philip.
