Custom fields on products added to cart
10 years 1 month ago #252825
by Juravle
Custom fields on products added to cart was created by Juravle
I have created severals products i saved them in different categories. At specific category I published some costum fields, and at other category diferent custom field.
The custom fields are displayed Ok on the products assigned, but when you add to cart products of different categories, every product displays on order form all the custom fields, including the custom fields that are assigned to the other product added to cart.
Is there any solution, to solve this and avoid that product displays the costum fields assigned to an other product and category when both prodcuts are added to cart.
P.D. I use a smartaddon module cart : SJ Mini Cart Pro
www.smartaddons.com/extensions/commercia...kashop-joomla-module
10 years 1 month ago #252901
Replied by nicolas on topic Custom fields on products added to cart
Can you enable the HikaShop cart module on your website and see if you still have the problem with that module ?
If you do, then it means that there might be an issue in the version of HikaShop you have. Update if you don't have the latest and save the settings of the custom fields. If you still have the problem, we would need a link to the pages you're talking about and some step by step process to reproduce the problem.
If you don't have the problem with the default cart, it's likely that the problem is in the code of the SJ mini cart Pro module and you'll have to check on that with them.
10 years 4 weeks ago #253272
by Juravle
Replied by Juravle on topic Custom fields on products added to cart
I did what you asked me and with hikashop cart happens the same thing, so it´s a bug. Give me your email to send you step by step guidance to checkou process and creditianls to access the site.
10 years 3 weeks ago #253299
You can use our contact form in order to send all that:
Please make sure you also provide a link to this thread for reference.
10 years 3 weeks ago #253379
I don't see any problem on your website.
You've created custom order fields which only display when you purchase a product from a particular category.
When you go to the checkout and you have one of these products in the cart, the fields are displayed, otherwise, they aren't.
That's how it's supposed to be.
And if I have only product product, I don't see the custom fields of the other product. So it seems that what you're describing ('when you add to cart products of different categories, every product displays on order form all the custom fields, including the custom fields that are assigned to the other product added to cart') is not happening.
So maybe I didn't understand something in what you explained as I couldn't find any problem.
If you do have a problem, please provide screenshots of the settings and of the results so that we can have a clear understanding of the problem.
10 years 3 weeks ago #253505
by Juravle
The problem is that could not give a good impression to clients, to see on "Aditional Información" tab the custom fields of all the products on the cart mixed and without any separation.
Also, if the client during the checkout process of the first product added to cart, change his mind and decides to add an other product to cart, once he fullfiled the aditional infomration of the first prodcut added to cart, when he add the second product the custom fields of the first product are also displayed creating a confusion as those custom fields are also part of this second prodcut. I don´t know if you are able to understand my concern?
In other words, is there any configuration of the custom fields possible in order to avoid when two products are added to cart that their individual custom fields being displayed togheter?
What I need in fact is to sell forms through hikashop: so in such way that the form of the product should be hided till consumer click the add to cart button?
Thanks and my apollogies if my english level makes things harder to undertand to you..
10 years 3 weeks ago #253543
I understand what you mean but the problem is not that there is a bug, is that you're trying to use custom order fields for something they are meant to.
Why not create custom fields of the table "item" instead of custom fields of the table "order" ?
That way, they would appear on the product page and the customers would fill then in each product when adding the product ot the cart. And you wouldn't need anything during the checkout.
