nasty problems with taxes and coupons
- gpiraccini
10 years 2 weeks ago #254878
by gpiraccini
nasty problems with taxes and coupons was created by gpiraccini
-- Joomla version -- : 3.6.4
-- PHP version -- : 5.6.26
Dear Hika Shop,
can you please assist me in finding a solution in coupon tax calculating.
The discount value of the coupon is always calculated on the gross price independently if I set "Product tax category" or not in the Coupon configuration.
In my case I'm showing all net prices, and I would like to show also coupon discount amount as net.
This problem create errors also on the tax calculating.
# Here what it is shown:
Subtotal 143,00 €
Coupon -59,49 € *
IVA 4 % 3,34 € *
Total 89,23 €
(the sum doesn't match 143.00-59.49+3.34=86.85)
# Here what should correctly be:
Subtotal 143,00 €
Coupon -57,20 €
IVA 4 % 3,43 €
Total 89,23 €
You can try it yourself in this test website.
www.iandp.it/test/
Product to choose: "Grand Cru Musignano - Can 5 L"
Coupon to add: "JH40SP" (this is a 40% coupon)
If you need, I can send you in private the admin login credentials.
Thanks for your support
Greg
Dear Hika Shop,
Subtotal 143,00 €
Coupon -59,49 € *
IVA 4 % 3,34 € *
Total 89,23 €
Subtotal 143,00 €
Coupon -57,20 €
IVA 4 % 3,43 €
Total 89,23 €
www.iandp.it/test/
Greg
10 years 2 weeks ago #255099
Replied by nicolas on topic nasty problems with taxes and coupons
On top of the "product tax category" setting of the coupon, you also have the "apply discount" setting of the HikaShop configuration, in order to control how the coupon values will be calculated.
So please try the different combinaisons of both options and one of them should do what you want.
- gpiraccini
10 years 1 week ago #255322
by gpiraccini
Replied by gpiraccini on topic nasty problems with taxes and coupons
I've tried all the four combination having always the same result.
here attached an example image.
Greg
Greg
10 years 1 week ago #255377
I'm not able to reproduce the problem.
Please provide a backend access and a link to this thread via our contact form so that we can have a look at that.
10 years 1 week ago #255476
by Philip
Replied by Philip on topic nasty problems with taxes and coupons
For a reason or another I'm unable to add your "product test" to the cart...
There is no button "add to cart"...
Thanks to make the required change in order to able us to process some tests.
Awaiting news from you.
- gpiraccini
10 years 1 week ago - 10 years 1 week ago #255494
by gpiraccini
Hi Philippe,
Notthing strange on my side, here attacched I post you the process I can do.
Can't you see the same?
www.iandp.it/test/en/boutique-en
Greg
Greg
Last edit: 10 years 1 week ago by gpiraccini.
10 years 1 week ago - 10 years 1 week ago #255756
by Philip
I just have a look on your configuration, and I get it, you don't link your coupon with your tax applied on this product.
And so, I you want to get the tax really applied AFTER the discount reproduce this configuration in your Coupon configuration :
The 44% in order to avoid to reduce your discount with the tax add to your Coupn
Hope this will help you.
Last edit: 10 years 1 week ago by Philip.
- gpiraccini
10 years 1 week ago #255778
by gpiraccini
Hi Philippe,
I've tried your solution, to reach the correct discount and VAT I had to use a percentage of 38.462% (40% / 1.04 VAT). But still the Total doesn't match. (please see attachment)
This happen either if i set Discount TAX calculation Before or After taxes.
Sorry for this, but I think that the discount percentage shouldn't be modify, this because the discount should be applied to the Subtotal indipendently if it is Gross or Net. It is a percentage so this shouldn't create any arithmetical problem.
Greg
Greg
10 years 1 week ago - 10 years 1 week ago #255839
by Philip
I spent time on your cart and tax configuration, and the calcuation is right, it's the display which is wrong!
You choose in Configuation Main in "of which VAT" to don't display product price WITH tax BUT of course total price is WITH taxes and so that can't be logical with a quick view.
I set this :
And as result I get this :
Maybe the way tax is displayed can seems wrong, maybe add an little message like "with" or "include" can be more clear.
Make an override view in the checkout - cart.php
Hope that will help you to have what your want.
I set this :
- gpiraccini
10 years 1 week ago #255858
by gpiraccini
Hi Philippe,
I'm sorry you get it wrong, this was not my intent.
The one you exposed is the actual method we are using in the live environment. We have also modified the VAT description (di cui IVA 4%) = (of witch VAT 4%). But this is not what the client is asking.
I don't know in other countries but in Italy commercial invoice are all done as follow:
List of Products (excluded VAT)
Subtotal (excluded VAT)
Discount (on Subtotal)
VAT 4% (on sum of all 4% products * (1-discount %))
VAT 22% (on sum of all 22% products * (1-discount %))
Total (sum Subtotal-Discount+VAT 4%+VAT 22%)
So this look normal to me, and this is way I was asking for a check on this.
Now I understand there is no way to reach that goal. I've take a quick view of your code and I understand it is too much structurated to make a simple override for this situation.
Thanks for your time
Greg
Greg
