module problem
- ebrahimahamdi
9 years 9 months ago #263483
by ebrahimahamdi
module problem was created by ebrahimahamdi
9 years 9 months ago #263484
by Jerome
Replied by Jerome on topic module problem
If you take a look at your URL, you'll see that you're using the same Joomla menu for your checkout.
You need to create a dedicated menu for the checkout and use the HikaShop setting to force the checkout on that menu.
