Billing and Shipping addresses problems
9 years 8 months ago #265731 by Displey
-- Joomla version -- : 3.6.5
-- PHP version -- : 7.0
Hello!
I use new checkout system. I like it but I have a problem with billing and shipping addresses.
My problem is:
I have both addresses selected. When I change one, the second changes too - I attached pictures. When I have 4 addresses ( the same 2 addresses in 2 columns) - it became possible to select which address I want. But 4 addresses are too much)))
The question is:
- Is there any possibility to display only one billing or shipping address? And allow customers to change it as need.
- Or to show checkbox "The same as billing address" - as in old checkout?
Regards, Olga
9 years 8 months ago - 9 years 8 months ago #265732 by Philip
Can you provide an Url link (and if needed access references), because from what I can see on your screenshot your address selector seems strange.
See mine (on Protostar), I can select on address or another without it modify the other thanks to this dropdown.
Awaiting news from you.
Last edit: 9 years 8 months ago by Philip.
9 years 7 months ago #265873 by Displey
Hello, Philip!
Thank You for Your answer!
I changed my template to template Protostar - selector's behavior the same as with my template. I attached a picture.
My site is dostavkafili.ru
If You need access references to back-end I can send it to You.
Regards, Olga
9 years 7 months ago #265881 by nicolas
Change the "address selector" setting of the HikaShop configuration to "dropdown" and you'll get the same display as Philip. It will probably be better than the "list" selector you're currently using.
9 years 7 months ago #266069 by Displey
Hello!
Thank You for advices - I tried but it didn't fix problems... So I found my own solution. Maybe it'll be helpful for somebody...
I need only one address ( shipping address ) for my customers on this project. So I made the second address invisible by css rules ))))
If somebody needs, css rules are here :
.hkc-sm-6.hkc-xs-12 {display:block; width:100%!important; margin:auto; text-align:center; padding-left:10%; padding-right:10%;}
fieldset.hika_address_field.hikashop_checkout_shipping_address_block {visibility: hidden;height: 10px;}
Thank You so much!
Olga
