- Thank you received: 4
Error when adding products to cart
9 years 7 months ago #266877
by mrooke
Error when adding products to cart was created by mrooke
-- Joomla version -- : 3.6.5
I am having a strange error - When I go to a product using my site's main menu such as this one:
superiorsignal.com/smoke-products/air-sm.../5-e-electric-blower
and i use the add to cart button, I get a 403 Forbidden page error ( superiorsignal.com/smoke-products/air-sm...r/product/updatecart ) - Ive never seen this "/updatecart" before
If however i go to a hikashop category page, click the product image and get to the same product:
superiorsignal.com/smoke-products/air-sm...-5-e-electric-blower
and i use the add to cart button, it works just fine.
The URL is certainly cleaner with the menu option and i do have this cleaner url set in the product's canonical URL field. I tried removing that but there was no change. This was all working fine yesterday... I dont remember making any changes.
9 years 7 months ago #266878
Replied by nicolas on topic Error when adding products to cart
The updatecart link is the link used by the add to cart system so that's not a problem, it's the normal URL. The thing is that it shouldn't generate that error. Do you have some kind of security extension like AdminTools or mod_security ?It might be related to that ?
Otherwise, you could try circumventing the problem by turning off the "add to cart legacy" setting in order to use the new add to cart system of HikaShop 3.
That might help avoid the error.
