Problem with the cart and check out
- Nembiewithhikashop
9 years 5 months ago #269105
by Nembiewithhikashop
Problem with the cart and check out was created by Nembiewithhikashop
Hello i have a few problems.
problem 1: After i add a product to my car it automatic goes to check out. How can i change that so it only add to the cart and i can keep shopping?
Problem 2: i cant delete anything from my cart even though i add delete item under the module but it isn't showen in the front end?
Problem 3: How can i add margin to my check out page?
Problem 4: How can i use the thumbnail pictures of the products instead of the big pictures because the pictures are taking alot of room?
Problem 5: how can i add a back button because there is only af next button
9 years 5 months ago #269108
Replied by nicolas on topic Problem with the cart and check out
1. You can enable the HikaShop cart notification plugin via the Joomla plugins manager.
2. Probably because there isn't enough width available where you added the module.
3. I don't understand your question. Where exactly do you want to add that margin ?
4. That should be the case, unless you configured too big numbers in the thumbnails width/height settings of the HikaShop configuration or turned off the "thumbnails" setting there.
5. You need to enter the URL you want for that button in the "Continue shopping button's URL" setting.
9 years 5 months ago - 9 years 5 months ago #269196
Replied by Nembiewithhikashop on topic Problem with the cart and check out
Hello nicolas
To my first problem, It was already enabled, i tried to disable and there is no difference. the page still goes directly to the checkout page adding a product to the cart
Last edit: 9 years 5 months ago by Nembiewithhikashop.
9 years 5 months ago - 9 years 5 months ago #269198
by Jerome
Replied by Jerome on topic Problem with the cart and check out
* What HikaShop version number are you using ?
* What is your HikaShop "cart" configuration ?
* Could you provide a link to a product page so that we can see what you have ?
When you open a thread, please fill the basis fields in order to give the first information so our support team will be able to get the "first context".
Last edit: 9 years 5 months ago by nicolas.
Time to create page: 0.167 seconds
