Product not showing in cart module
9 years 5 months ago #270726 by PWessels
-- HikaShop version -- : 3.1.0
-- Joomla version -- : latest
-- PHP version -- : 5.6
Hello, I have used the hikashop module in pop up. when i click on the add to cart button the product doesn't add into the cart ?
Any help would be appreciated .
9 years 5 months ago #270758 by nicolas
From what I can see on your website, the issue is not with the module itself but how you add it in the popup.
Because if you go to the checkout, the cart is there, and I suppose that if you configure a HikaShop cart module to display in a standard position of the template, it should also display fine.
9 years 5 months ago #270852 by nico.van.leeuwen
I experience the same behaviour when adding products to the cart.
Having a module in the sidebar with the cart that is not updated right away.
When you press F5 then the products appear in the cart.
In the configuration I have the legacy options for adding to cart and checkout turned off.
Using Hikashop 3.1.1
9 years 5 months ago #270896 by nico.van.leeuwen
Hi, I found that my behaviour was caused bij a modification in the view "product>cart" . Removing/modifying this did the trick.
9 years 5 months ago #271061 by PWessels
Nicolas thanks for the reply.
I have always added the cart in a popup or a dropdown. feel if your cart is in a normal module position on a website it takes up to much space, like on my page.
evergreen.demoman.co.za/buy-online
So i have created the cart module and placed it into the atomic-cart-module position. I have then used Modules Anywhere to place it in the popup position.
9 years 5 months ago #271064 by nicolas
Do you know that since HikaShop 3, there is a "dropdown cart" setting for the mini cart setting of the HikaShop cart module ?
It allows you to have a cart module as small as possible with a sliding module when you click on it.
Also, as nico.van.leeuwen said, make sure that you don't have a view overrie for the file "cart" of the view "product" as it might not be compatible with the new add to cart system.
