problem view cart in mobile
9 years 5 months ago - 9 years 5 months ago #272253 by Casile
Sorry but not working the change in my template.
Where do i change this?
in the cart is related to your template CSS, which override the "padding-left" of that rule :
@media only screen and (max-width: 760px), (max-device-width: 1024px) and (min-device-width: 768px) frontend_defaul…1497531140:524 .hikashop_checkout_cart table td { border: none; border-bottom: 1px solid #eee; position: relative; padding-left: 30%; }
You might need to adapt the rule by marking it as "important"
Best regards,
Jerome
Last edit: 9 years 5 months ago by Jerome. Reason: removing duplicate attachment & adding [code] tag
9 years 5 months ago - 9 years 5 months ago #272273 by Philip
Replied by Philip on topic problem view cart in mobile
Can you provide a link in order to better understand the context?
Because maybe there is some "conflicts" with your front-end template or else, because in our mind HikaShop Css must be adapted for mobile screen.
Awaiting news from you.
Last edit: 9 years 5 months ago by Philip.
9 years 5 months ago #272299 by Casile
Replied by Casile on topic problem view cart in mobile
I send you in private the user name and pasword for access in joomla as super user.
9 years 5 months ago #272306 by Jerome
Replied by Jerome on topic problem view cart in mobile
Do not use private message to contact the team ; it's unfortunately useless because we are a team, we can't see PM of other users and PM is not a way to provide good support.
Thank you for your understanding.
Now about your issue ; it's something "recurrent" and it's an issue generated by your template.
You have two way to fix it (not in the same time. It's one.. or the other).
1 - Rectify the padding to mark it important.
In the HikaShop frontend CSS you will find that rule :
You need to set the paddin-left as important to force that padding and not let your template break it.
2 - Removing the "position absolute".
.hikashop_checkout_cart table td:before { position: absolute; left: 6px; padding-right: 10px; }
You need to remove the position absolute so the content will be display in two lines.
